S sdturbo Veteran Member Joined Sep 12, 2006 Location san diego TDI none Jan 2, 2009 #1 Will a ALH pump work on an AHU motor/ecu?
AThreeTdi Veteran Member Joined Oct 10, 2005 Location NJ TDI 06 jetta Tdi , 03 jetta Tdi Jan 2, 2009 #2 sdturbo said: Will a ALH pump work on an AHU motor/ecu? Click to expand... You have to machine the bracket, pulley, and the plug to make to fit. Here is the step by step; http://forums.tdiclub.com/showthread.php?t=152265 Last edited: Jan 2, 2009
