Old October 19th, 2008, 06:39   #1
richmondvatdi
Default Bump, bump, bump on acceleration ('03 TDI 5-speed)
Good Sunday Morning Everyone!
I am beginning to sense a very, very slight bump, bump, bump on acceleration. More noticeable in 2nd gear, less in 3rd, even less in 4th. It almost sounds like the beginnings of a classic CV joint failure, except it is on straight line acceleration, not while turning. It only happens when under load, and goes away as soon as I back off the accelerator to steady speed.
The speed of the bump increases with the speed of the car (as opposed to speed of the engine), so I suspect it is somewhere btw. the trans and the wheel.
CV joint boots are in good shape. Front wheels/lugs are tight.
2003 Jetta TDI Wagon
5-speed
165,000 miles
Any ideas?
richmondvatdi is offline   Reply With Quote
Old October 19th, 2008, 07:06   #2
speed185187
speed185187's Avatar
control arm bushings? or strut bearing plates?
2016 Model S P100DL
2020 F-450 Lariat
2018 Outback Limited (her's)
speed185187 is offline   Reply With Quote
Old October 19th, 2008, 07:11   #3
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
Inner CV's do this when under load and going straight, so you first evaluation may be correct.
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old October 19th, 2008, 10:41   #4
richmondvatdi
Default Inner CV Joints?
Is it possible the inner joints are bad even though boots are in perfect condition? Any time I've had a CV joint go bad, it was accompanied by a cracked boot that let dirt in. The dirt is what killed the joint.
I always thought CV joints basically lasted forever as long as the boot held up. Is my assumption not true?
Old October 19th, 2008, 14:16   #5
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
wear happens, even with lubrication.
DPM is offline   Reply With Quote
Old October 19th, 2008, 14:22   #6
Ski in NC
Fuel Economy: 48-52 typical
All four of the cv joints run at an angle even when going straight ahead. So a turn is not necessary for a worn cv joint to make a thump. The trick is finding out which one is responsible. Sounds like the inner ones have a reputation for this, so maybe a good place to start. -Eric
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old October 19th, 2008, 15:41   #7
richmondvatdi
This must be in the very early stages, because it is barely detectable. I think I will wait until it gets worse. That way I may be able to confirm what it is before pulling the front end apart.
If it is CV joints, is there any harm in letting it go for a while?
Old October 21st, 2008, 19:46   #8
richmondvatdi
Bump...
I'd like some opinions. Is there any reason not to let it go until it becomes more clear what the problem is, or should I just suck it up and pull the front end apart to confirm the inner CV joint.
Old October 21st, 2008, 21:02   #9
Ski in NC
If it is barely detectable, then I can't see any harm in running it. Aside from the failed joint itself, which you will replace anyway once identified.
-Eric
Old October 22nd, 2008, 11:01   #10
ninobigfish
TDI(s): 1998
Fuel Economy: 49mp
Were you able to find what was cousing the bump? I have he same problem. So, please let me know.
ninobigfish is offline   Reply With Quote
Old October 25th, 2008, 18:36   #11
ninobigfish
TDI(s): 1998
Fuel Economy: 49mp
Default Bump
I am having the same situation bump bump when on low velocity. does anyone could help me? a drawing could help. Thank you
Old October 28th, 2008, 18:16   #12
richmondvatdi
It has not gotten any worse in the last 2 months (~8,000 miles). I will continue to monitor. If it gets significantly worse, I will dig into it more.
Old October 30th, 2008, 19:52   #13
Caledoniatdi
TDI(s): 2002 Jetta
Fuel Economy: 50mpg
This sounds like what I experienced at around 140,000 miles, I replaced my clutch and that fixed the problem.
Caledoniatdi is offline   Reply With Quote
Old November 5th, 2008, 16:47   #14
richmondvatdi
Default I Would Not Have Suspected the Clutch
Wow. Interesting. I would expect the clutch to start to "grab" when it starts to go, not bump on straight-line acceleration...
Old November 5th, 2008, 19:45   #15
Dimitri16V
Dimitri16V's Avatar
Clutch it is..inner joints will click if they are dry or worn out
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Page generated in 0.17186 seconds with 10 queries
[Output: 117.52 Kb. compressed to 97.14 Kb. by saving 20.38 Kb. (17.34%)]
