Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old May 31st, 2008, 18:58   #1
WrEkkED
WrEkkED's Avatar
Default Fuel mileage Bump
So I finally did it. I'm going slow as hell. Speed limit on the highway, 90 in 80's. I filled up at Husky, also got their additive. Right now I'm at 540km on the tank, vented, at halfway. Was mainly highway, except for two slowww trips downtown.
I'm all excited!!
Gave the car a bath, got the hitch on, and shes going strong. ... except that damn wobbly axle!!!
2004 Jetta TDI Sport Edition
WrEkkED is offline   Reply With Quote
Old June 1st, 2008, 14:49   #2
yatzee
yatzee's Avatar
TDI(s): see sig
what's your best tank to date?
2015 Passat TDi 6 spd, 2008 WK CRD, 1991 405 mi16, 1992 300D, 1986 and 1987 190e 2.3-16, and a couple 2 wheeled things
yatzee is offline   Reply With Quote
Old June 1st, 2008, 15:23   #3
Silver02TDI
Silver02TDI's Avatar
6.3L / 100kms on the last fill, with mostly highway (Napanee to Toronto, then up for the cruise yesterday)
2015 Highlander Hybrid Limited
2015 Passat TDI Comfortline / Sport Pkg
2012 Golf Wagon TDI 6spd Highline /w Nav (Bought Back)
2002 Jetta TDI (Traded)
Silver02TDI is offline   Reply With Quote
Old June 1st, 2008, 15:31   #4
OmegaRenegade
OmegaRenegade's Avatar
TDI(s): 2004 Jetta
6.3L/100km's but a good portion of that your boost valve was incorrectly set up - your next tank should take you a bit further... if not we can look into other reasons why its not up to par. Maybe you just have a heavy foot??
6.3L/100km's is only 0.4L/100km's beter then what i get - i have a VERY heavy foot tho and drive a PD.
2004 Jetta TDI 5 Speed 420 000km PD130 ASZ Engine
SLIGHTLY Modified
OmegaRenegade is offline   Reply With Quote
Old June 1st, 2008, 16:18   #5
4lowdubs
4lowdubs's Avatar
TDI(s): 2001 mk4
4.9 L / 100 km is my best tank, im consistantly getting over 1100km on about 56, 57 L per fill ( mostly highway,,401.)
2001 Mk 4 Golf, 5 spd, 2 dr.
BBS RXII's, EMT tune, 1856 (24psi), pp502's, long runners, Dual Diaphragm VR6 Clutch, 2.5 turboback (PP DP no cat), EGR & cooler delete, boost and
EGT gauge, PD lift pump, widget, Koni Sport Cup Kit, Neuspeed 28mm Rear SB, Evo Skid Plate, Hybrid Dogbone mod, CCV vent mod, AEM Cold Air Intake Dry Filter, 172 whp.
4lowdubs is offline   Reply With Quote
Old June 2nd, 2008, 06:14   #6
Sweeps
Sweeps's Avatar
Including the cruise Saturday, and the drive to work the day before, some running around yesetrday, and the drive to work today, SG says 4.6L/100km, which is pretty accurate lately, and I've gone 700km on half a tank.
Silver you should be getting better?? We have similar mods.
The WORST I've ever gotten was 5.8L/100km in the dead of winter, on snowies, with a 140km/h average.
Steve
- MK4, MK5, MK6 Jetta TDI's in the past
- 2013 Outback 2.5i - wife's commuter
- Subaru Demo
- 02 BMW 330i - weekend fun.
Sweeps is offline   Reply With Quote
Old June 2nd, 2008, 07:26   #7
SuperJ
SuperJ's Avatar
Fuel Economy: too much fun...
Just filled up yesterday. 1007km's on 52.6 litres, I think thats 5.3 or 5.2L/100km. That's driving 115km/hr most of the time.
2011 Tiguan 6spd MT, w/sport package.
SOLD '06 Jetta Mufflerectemy, RC1+, 140WHP, VR6 Clutch, Mobil1 TDT
300,000km and counting
SuperJ is offline   Reply With Quote
Old June 2nd, 2008, 07:40   #8
yatzee
yatzee's Avatar
TDI(s): see sig
I just got 6.1l/100 on B100, driving my poor car like I stole it.... Not bad I suppose, and that includes a fair amount of city
Old June 2nd, 2008, 12:00   #9
dataiv
dataiv's Avatar
I always vent, pretty well buy whatever fuel is the cheapest, and drive about 115 on the hwy ... last 3 tanks:
4.60 L/100km on Shell Ultra (57.391L over 1247km)
4.67 L/100km on Flying J fuel (54.17L over 1159km)
4.88 L/100km on W.O. Stinson Fuel (Pembroke)
In the winter I averaged about 5.4 L/100km.
If you're driving all highway you should be getting better than 6ish I think.
2011 Golf Wagon TDI 6MT (164997km bought back by VW)
2015 Golf Wagon TDI 6MT (135000km)
dataiv is offline   Reply With Quote
Old June 2nd, 2008, 16:48   #10
WrEkkED
WrEkkED's Avatar
My best tank was 1100km without venting, going 120 on average. I got 1100 all the time. I think these smog 216's must be what took it so much lower. All winter I was around 600-700 unvented. Last tank was vented and I got about 700 but that was 80% city.
Note: I don't drive till the light comes on.
I wish I got the economy I used to, but I'm happy enough unless anybody has some other suggestions. IQ? etc.
Running stock size Yoko's at 40psi. Clean intake manifold, good timming belt.
Old June 2nd, 2008, 16:57   #11
yatzee
yatzee's Avatar
TDI(s): see sig
I know in my car, I had to vent to get into the 1000's consistantly.
Old June 2nd, 2008, 17:25   #12
craig01b
craig01b's Avatar
TDI(s): None
Hmmmm...slow down...I am at 5.2 normally...90 highway, 10 city...120 k's with cruise on the highway, otherwise rather slow....well, most days anyways.
I can bump it up to 4.8 if I keep off the go pedal, and stay at 115 or below on the highway...stock tires, at 32 psi....rears get bumped up with the load, but, that is unusal...After 110 kph...drag becomes a huge factor. Well, in my opinion anyways. In the winter, with idling, and really cold temps, things bump up a little....stiff engine oil, stiff bearings, stiff gearbox...and extra elex to run the heated seats...
Craig
All retired, bought a Subaru.... all wheel drive, and a little bigger than the high line. Time will tell!
craig01b is offline   Reply With Quote
Old June 2nd, 2008, 18:39   #13
redlinedave
redlinedave's Avatar
Fuel Economy: around 5.9/100
Since I put in J Morrisons 205s injectors In getting 950 to 1100 km a tank
55L ish.Depends on how much city Im doing.Most times Im 600 to 650 by
1/2 tank mark.I drive a Waggon with a 5 spd stick tyres at 45 psi
oh-sree vaggon
redlinedave is offline   Reply With Quote
Old June 3rd, 2008, 05:42   #14
Tsagoth
Tsagoth's Avatar
With the slushbox, my best tank ever is 5.3 L/100km. Summer normal range is 5.4-5.7 L/100km. Over the winter it was 6.2-6.8 L/100km, but I attribute part of that to the failing tranny.
A couple of weeks ago I tried dawdling at 73km/hr for 120km and was rewarded with a 4.8 L/100km but that's just too slow for normal commuting.
Tsagoth is offline   Reply With Quote
Old June 3rd, 2008, 17:53   #15
WrEkkED
WrEkkED's Avatar
I wonder if my f'd up axles might be making things out of wack.
I'm fine with my economy. I go slow to stop slights, downshift when I have time. I take my acceleration slow unless I need to be fast. Keep cruise at 100km/h on the highway. I think my car just doesn't like to be as efficient as the others, but it still does fine. Mid to high 40's. But either way, it's gotten way better since I slowed it down.
Page generated in 0.16334 seconds with 10 queries
[Output: 123.63 Kb. compressed to 101.58 Kb. by saving 22.04 Kb. (17.83%)]
