Old December 30th, 2018, 17:52   #121
Cheapskatepilot
I cant access the database...can anybody tell me the weight of a 17" rim with part number5K0601025F8Z8.
Cheapskatepilot is offline   Reply With Quote
Old August 1st, 2019, 04:39   #122
Powder Hound
Powder Hound's Avatar
I don't know what wheel that is, and so I'm not looking at the database. I can tell you that VW 17" alloy wheels tend to run 23-23.5 pounds each, about the same as a 15" steelie.
If you need a more accurate weight than that, someone else will have to chime in. Also, do you want weight with or without the valve stem?
Cheers,
PH
Old November 4th, 2019, 06:49   #123
X@V
X@V's Avatar
Myturbodiesel and 4130 not working now...
Jetta 1985 BKD, crazy QUATTRO!
Audi A4 B6 : V6 2.5tdi
B7 A4 wagon Quattro
MQB Tiguan Highline
X@V is offline   Reply With Quote
Old May 4th, 2020, 10:25   #124
dkort2
TDI(s): 2003 beetle
I want to change the wheels on my 2003VW beetle.
What is recommended. Live in Windsor Ont Canada. And would be dealing with Canadian Tire
dkort2 is offline   Reply With Quote
Old May 4th, 2020, 15:12   #125
Powder Hound
Go with OEM wheels, and you'll be fine. 5x100 bolt circle. 15, 16, or 17 inch. I'd recommend 16 inch, as you'll get a little better handling available, and the tire prices are a little easier on the wallet as opposed to 17s. 18 inch wheels are probably available, but they're just silly as in expensive, and the guy mounting them won't like you very much. That's because it is significantly more difficult to mount low profile tires, and the 18" size are 40 percent in aspect ratio. If you stick with OEM, you won't have to buy new lug bolts.
This is assuming you currently have OEM wheels.
Is that what you're asking? Any other details you'd like to provide? The wheels list at the beginning of this thread show the available wheels, but some of them are very hard to find. Having said that, those available from private sellers probably won't be perfect, but they're a LOT more affordable than new retail. And if you just look locally, you'll find the shipping a lot more reasonable since you just go get them.
Cheers,
PH
Old May 4th, 2020, 15:18   #126
Nuje
Yep - stick with OEM rims. Aftermarket - you deal with adapter rings (which often don't fit perfectly, and you have to buy new bolts - around $4-5 each, so $100 after tax for a 20-pack, plus probably deal with the stupid lug bolt "key" that lots of aftermarket bolts use.
For the 2003 Beetle, as Power Hound says, 16" is the sweet spot: lots of tire options, good price, handle nicely. A good do-everything, year round tire (even for winter) is the Continental DWS 06 (Dry, Wet, Snow).
Check out Kijiji or Facebook Marketplace near you - there's always people looking to get rid of rims / tires. Just be sure they're 5x100 (ask or look for part number; if it starts with 1J* or 1C*, you're good; if the second letter is a K - like 1K0 *** ***, that's a 5x112.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, Adaptive Cruise retrofit
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Page generated in 0.13671 seconds with 10 queries
[Output: 80.29 Kb. compressed to 69.67 Kb. by saving 10.61 Kb. (13.22%)]
