Old May 29th, 2020, 13:08   #1
gguazzoni138
TDI(s): 2015 GSW
Default Tubular Sway bars on 2015 GolfSportwagen?
Forgive me if this has already been discussed or is in a different thread but does anyone know if the sway bars on the 2015 Golfs are hollow or solid? I’ve looked here and on the web but to no avail.
I bought a thicker sway bar. It’s not as thick as I would like and I am trying to see what I should expect in terms of handling improvement.
Thanks!
gguazzoni138 is offline   Reply With Quote
Old May 31st, 2020, 18:12   #2
pebjr
Here is a thread discussing rear sway bar.
http://forums.tdiclub.com/showthread.php?t=476283
pebjr is offline   Reply With Quote
Old May 31st, 2020, 20:35   #3
gguazzoni138
TDI(s): 2015 GSW
Iím a little confused. The 2015 GSW uses a torsion beam rather than a bar? I havenít jacked it up yet but sticking my head under there doesnít seem like itís a beam?
Old May 31st, 2020, 22:16   #4
Cuzoe
TDI(s): MK7 Golf S
Not sure what you mean by "torsion beam rather than a bar" but the rear is a torsion beam. The Mk7 TDI Golf/GSW does not have independent rear suspension.
Neuspeed is the only company that makes a sway bar for the torsion beam rear. It is advertised to reduce the twisting of the torsion beam that occurs when turning.
Neuspeed, 034, SuperPro and H&R have front swaybars (various diameters, solid/hollow, all appear to be adjustable) with Mk7 TDI fitment so you've got options there.
FWIW, these front bars also fit the GTI/TSI so it's likely that front bars from other manufacturers will also fit the TDI. I would assume those manufacturers have not been able to finding e fitment on a TDI so they don't include it in their fitment list. Neuspeed describes their bar relative to the stiffness of the stock GTI bar. Would have to check part numbers but I suspect the GTI stock front sway is already stiffer than the stock sway on the TDI.
Sent from my ONEPLUS A6013 using Tapatalk
Cuzoe is offline   Reply With Quote
Old June 1st, 2020, 10:26   #5
gguazzoni138
TDI(s): 2015 GSW
Thank for the reply. Iím just so surprised it doesnít have IRS. I got it sorted out now.
Thank again!
Old June 2nd, 2020, 08:53   #6
gguazzoni138
TDI(s): 2015 GSW
What benefit would you see from a stiffer front bar? Wouldnít it just bias the car to understeer more?
MK7 2015 Golf / Golfsportwagen Frost Heater snoocher Private TDI Items for Sale/Wanted 3 October 28th, 2019 10:13
2015 Jetta TDI anyone install bigger sway bars fastcar4re VW MKVI-A6 Jetta Sedan (~ 2011+) 2 November 4th, 2017 18:16
WTB B7 2012-2015 Sway bars 740GLE Private TDI Items for Sale/Wanted 0 May 1st, 2017 05:30
sway bars for 2015 and suspension fitment question glong VW MKVI-A6 Jetta Sedan (~ 2011+) 0 August 4th, 2015 17:21
WTB: Strut Bars, Braces, Maybe Sway Bars GOLFA4TDIPD Private TDI Items for Sale/Wanted 1 November 28th, 2004 23:44
Page generated in 0.13648 seconds with 13 queries
[Output: 75.11 Kb. compressed to 65.88 Kb. by saving 9.23 Kb. (12.29%)]
