SparkyWagon
had a wagon donor, everything swapped from that car. deleted immo and i dont see where i have to manually wire anything
i have the car 100 percent together, it has the glow plug relay in the cowl by the windshield and it is getting power. car wont start i was wondering what exactly you have to wire because there is nothing that isnt connected. i used a mighty vac to prime injection pump and cracked the hard lines. think might be an air leak somewhere because after cranking it sounds like to fuel dumps back into the tank after done cranking, unless its from the return line. i am going to check this today. i am scratching my head and just want it done.
any feedback would be great thanks
