Old March 15th, 2019, 09:27   #1
Dalon
Fuel Economy: ~42
Default Replace bad glow plug or all?
Hello all. Got a CEL last night, scanned for codes and it was P0673 for cylinder 3 glow plug. My question is, should I replace just that single glowplug that is bad or all 4? Iím not sure when, if they even were replaced before. Thanks!
2006 Jetta TDI - 190k - EGR & Cooler Delete - ECS Dog Bone Insert - Frank06 Cam - Muffler & Resonator Delete - VCDS mods
2013 Passat TDI - 15k - VCDS Mods
Dalon is offline   Reply With Quote
Old March 15th, 2019, 09:34   #2
csstevej
Personally I’d do just the one, check the rest , and motor on.
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old March 15th, 2019, 10:01   #3
belome
Fuel Economy: 47'ish
Personally, I'd look at the wiring harness before doing anything.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is online now   Reply With Quote
Old March 15th, 2019, 10:13   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Good advice. You can also check the plug with an ohm meter to verify it is in fact bad, then do all 4.
Replace one glow plug or replace all? bherman13 VW MKV-A5 Golf/Jettas 19 October 21st, 2015 20:54
ODB Glow Plug Open Circuit=Bad Glow Plug? dgoldsmith VW MKV-A5 Golf/Jettas 7 September 13th, 2014 20:41
Can I replace just ONE glow plug? jayoldschool TDI 101 12 October 1st, 2013 16:44
One glow plug bad, replace one or all four? noother TDI 101 17 March 2nd, 2008 20:35
Replace one glow plug or four? Davin VW MKIV-A4 TDIs (VE and PD) 11 June 21st, 2004 08:24
Page generated in 0.12456 seconds with 13 queries
[Output: 62.61 Kb. compressed to 55.96 Kb. by saving 6.64 Kb. (10.61%)]
