Old December 12th, 2018, 17:51   #1
sloinker
sloinker's Avatar
Default ERROR: Service vehicle. Only leave vehicle in P position
Seems there is now a recall for this problem. A buildup of dirt on a shifter mechanism component may allow the removal of the key while the car is not in park. Info follows:
Compliance Recall 37L5 Shift Lever Micro Switch
What vehicles are included in Compliance Recall 37L5?
Certain 2015-2018 model year Volkswagen Golf and Golf SportWagen vehicles.
What is the concern for Compliance Recall 37L5?
Over time, a build-up of silicate on the shift lever micro switch contacts can make it possible to remove the key from the ignition switch without the shift lever being in the "P" Park position. This makes the vehicle noncompliant with 49 CFR 571.114 Standard No. 114 Theft protection and rollaway prevention. If the ignition key is removed without the shift lever being in the "P" Park position, there is a risk that the vehicle may roll away, resulting in a crash that could injure people and damage property.
What is the repair for Compliance Recall 37L5?
When parts become available, dealers will install an additional switch and circuit board.The recall repair will be FREE.
When will the repair for Compliance Recall 37L5 be available?
This recall repair is not yet available.
Are there any precautions I should take because my vehicle is part of Compliance Recall 37L5?
Yes. If this condition is present in the vehicle, an audible warning sound and failure message may appear in the instrument cluster. If this happens, owners are advised to contact an authorized Volkswagen dealer immediately and make arrangements to have the vehicle serviced.
How will I know when I can get my vehicle fixed under Compliance Recall 37L5?
Volkswagen will send you a letter via first-class mail when the recall repair is available for your vehicle. Until then, if you have any questions or vehicle concerns, please click here to find a Volkswagen dealer or click here to Contact Us.
sloinker is offline   Reply With Quote
Old December 12th, 2018, 18:56   #2
cristoaca
Thank you for posting this. I have been getting this error message intermittently and more often at the first start on cold mornings.
It shows on the instrument cluster only for a second and is associated by a short beep.
cristoaca is offline   Reply With Quote
Old December 14th, 2018, 05:26   #3
740GLE
Been an ongoing repair item for DSGs on the mk7 platform, common error on GTIs as well.
I think I've only had the error when moving the DSG shifter from P without pressing the button.
Old December 14th, 2018, 12:06   #4
Martin Winterkorn
After a long drawn out ordeal, both the local dealer and VW of America have denied to fix my TDI with this exact issue because it is not included in the 33,168 select Volkswagen Golfs and Golf Sportwagens from 2015 to 2018 model years.
The local dealer confirm that this is the exact issue we have been dealing with since July of this year. Most recently I was going through the pharmacy drive-thru and in Park when the vehicle began to roll forward which I had to hit the brakes to stop it.
Yet with all the evidence to include the ECU/TCU logs verifying the problem since its not a "affected" VIN, they will do nothing but issue a complaint to NHTSA and VW internally in hopes that if they get enough complaints more VINs will be recalled.
I understand this is an extremely common issue affecting all MK7's but VW is really dropping the ball on this one. Maybe the POS will roll away on me and I can take legal action at that point.
Martin Winterkorn is offline   Reply With Quote
Old December 17th, 2018, 04:54   #5
740GLE
In park? so the pawls were engaged? did you get an error on the dash when this roll forward happend? The DSG does have a crazy amount of "roll back" in the DSG something like 1-2 feet before the pawls engage and actually stop the car.
Old December 17th, 2018, 21:32   #6
Martin Winterkorn
Yes, while in park. The pawls were engaged. I did not get the error when the roll forward happened. I have only ever had it happen while driving. Everything from 10mph to 80mph. No particular speed seems to trip the error.
Old December 22nd, 2018, 19:21   #7
bluebus
Default Same error
I had the issue with the error popping up and the shift assembly was replaced under warranty. This seemed to fix the issue temporarily. Now the error is back intermittently, and becoming more frequent. I checked the recalls for the car and none are listed. I will report it to the local dealer and see if they know anything about it. Kind of glad there is an acknowledgment of the problem since so many seem affected.
Edit: Went ahead and filed a NHTSA complaint to do all I can to expand the recall.
bluebus is offline   Reply With Quote
Old December 22nd, 2018, 20:22   #8
sloinker
sloinker's Avatar
It sounds like the shifter replacement doesn't fix the problem if the recall is correct. The addition of a printed circuit board and a switch seems to be the real fix. Time will tell.
Old December 25th, 2018, 11:51   #9
bluebus
Agreed, definitely silenced the issue until I was outside of warranty, however On mine, the error seems to happen mostly when driving in wet conditions, so I assumed it was some sort of electrical gremlin. Never had the car try to roll away in park, however.
Old December 25th, 2018, 20:07   #10
Martin Winterkorn
Doesn't rain much here in AZ and I get it a ton when it is hot in the summer. Since its cooled down for the winter I see it about once a week now.
Old December 27th, 2018, 16:14   #11
bluebus
It's funny, because the first time I had the issue, before the warranty repair, it was very random, and got increasingly more consistent until the warning finally stayed on. This time around, it does seem to happen mostly when I've been driving in wet conditions for a day or so. It's been going on for probably close to a year at this point, intermittently. I just hope they finally come up with a real fix.
Old January 29th, 2019, 22:07   #12
JBizz
"...with all the evidence to include the ECU/TCU logs verifying the problem..."
Wait what theirs logs? dealer never told me they can look it up. Ive had this problem since 2016 on and off. i had to drive around with a dash cam on my steering wheel to catch the error.. lol This is good news for me mine would Ill have to keep checking in. Thanks
2015 Golf TDI S (no name)
1993 Honda Del Sol (Blue MnM)
1970 chevy Noova (monkapotamus)
JBizz is offline   Reply With Quote
Old February 5th, 2019, 20:42   #13
redecop
TDI(s): Golf
Subbed! Had my car for almost a year now and its been doing this on and off. Excited for the fix.
redecop is offline   Reply With Quote
Old March 15th, 2019, 05:49   #14
redecop
TDI(s): Golf
Any more updates in this?
Old March 15th, 2019, 07:05   #15
sloinker
sloinker's Avatar
It is only certain vehicles dependent on their VIN that are covered. Mine isn't on the recall list but still should be covered by the basic warranty 3 year 36k miles from first sold purchase date. In my case I bought both of my Golf's "New" in 5/2017. One had 60 miles and the other 500. First titled by me. I called and talked to VW and they took my data and added my VIN to the NHTSB database for possible recall expansion in the future. I will probably have it looked at when I do the phase 2. My daughters car doesn't get the goofy message but hers is a sportwagen with push button start.
abs service and airbag service warnings triggered by annual vehicle inspection (MA) billmc2010TDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 March 24th, 2012 13:42
What about the vehicle service contract on passat sooner VW Passat Family (NMS and B7) TDIs (2012+) 0 August 29th, 2011 22:32
Compass Issue (Vehicle Position Recognition Control Module (J603)) pawel VW MKV-A5 Golf/Jettas 2 December 22nd, 2010 10:09
Vehicle negotiation services and vehicle financing Y2KBuggy TDI 101 2 February 25th, 2005 04:55
"If you acquire a 49 state vehicle (vehicle manufactured for all states except Ca)" Cullen VW MKIV-A4 TDIs (VE and PD) 6 June 12th, 2001 23:32
Page generated in 0.13057 seconds with 13 queries
[Output: 126.60 Kb. compressed to 105.75 Kb. by saving 20.85 Kb. (16.47%)]
