Having trouble with my immobilizer and it seems the cheapest fix is to buy the ecu, cluster, ccm and keys off eBay and swap them.
I have no problem doing this myself and have vcds if needed, also the kit comes with everything programmed together so it should be a straight forward swap with no codes needed and all that.
But what if the ecu P/N is different, eg:
Mine is:
038906019GL
the one i will purchase has different letters and the end but the same numbers, will this make any difference as i am changing everything anyway and the engine codes are the same?
Mine is:
038906019GL
