TDI Jetta Engine Block Cracked
jag
USA
Has anyone heard of any problem with engine blocks cracking at the motor mounts on a 99 Jetta TDI ?
godlike242
Bellevue, Wa
is that covered with the powertrain warranty perchance? or is that restricted to bits and pieces inside and VW will be a poop about fixing it?
GoFaster
Moderator at Large
Brampton, Ontario, Canada
2006 Jetta TDI
To answer the original question, I have never heard of cracked engine blocks on these engines. If you have one (which you haven't stated), then that's a first.
Brian P.
'96 Passat TDI mit UPsolute
