Old January 10th, 2018, 14:46   #1
morpwr
Fuel Economy: 40-60
Question DSG rattle or?
I bought a used 06 with DSG. It has rattled when cold since I got it. Once warmed up it is quiet. Have replaced alternator pulley and belt. Still has that "coffee can of tocks" sound when cold. The car has gone 80k since I got it. Everything works perfect. Is there any thing else that's can rattle? Thank you for any suggestions or help.
morpwr is offline   Reply With Quote
Old January 10th, 2018, 15:31   #2
banshee365
TDI(s): '13 Passat
A video would help. Sounds like it’s a good chance it’s your DMF.
banshee365 is offline   Reply With Quote
Old January 11th, 2018, 07:24   #3
JETaah
Once the engine warms up it does not vibrate as much and thus the flywheel has less damping to do.
Your description sounds like the typical worn flywheel symptom and they do wear out. No one escapes this. It is normal.
But, I would get with a guru that has dealt with this so you can to confirm it before shelling money out.
If you get it replaced, insist on getting the updated revision of the flywheel said to be an improved version. It has the letters CG at the end of the part number.
Cheaper flywheels (still LUK brand) can be found on Ebay, etc... of the previous version and they are usually just vendors trying to empty their shelves at bargain prices.
Old January 13th, 2018, 05:01   #4
morpwr
Fuel Economy: 40-60
Smile Surprised
I am surprised that it would be the flywheel. I was under the impression that once a flywheel was failing it was just a matter of a few hundred miles and it was done. I have over 50000 miles and it is not any noisier now than then. I thought it might be something else.
Old January 13th, 2018, 09:04   #5
crazyrunner33
crazyrunner33's Avatar
That's correct, though when hearing that sound, it's not a bad idea to have it inspected or start saving for a replacement. The reason it is made out to be such a boogeyman is because when it does decide to let go, it is not pretty. I'm starting to have the same symptoms on mine, so I'm planning to replace it by late spring.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
DSG Rattle morpwr VW MKV-A5 Golf/Jettas 6 December 4th, 2015 03:53
Bizarre DSG Rattle 2-5mph evantful VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 April 17th, 2015 17:14
06 dsg rattle when idling witmerj TDI 101 4 June 13th, 2012 09:13
How long on rattle DSG/DMF... benstdi TDI 101 2 December 14th, 2011 07:09
DSG Rattle Stuart Eng VW MKV-A5 Golf/Jettas 16 June 7th, 2009 19:37
Page generated in 0.13436 seconds with 12 queries
[Output: 68.06 Kb. compressed to 60.27 Kb. by saving 7.79 Kb. (11.44%)]
