Old January 12th, 2018, 07:26   #31
Tdi2015
TDI(s): 2015
Castrol Edge 5w-40 which meets MB 229.51. My thought process was that it was good enough for MB emission so it shouldn't ruin my system at least not in the next 10 or so month, but at the same time, because I run it hard provide a weight that can handle it. My MPG has dropped from about 50 mpg to 45, but I havent had to add any. My understanding was that the difference between the 504 and the 507 was that the 507 was produces SLIGHTLY less ash that would fill up my emission system.
Tdi2015 is offline   Reply With Quote
Old January 12th, 2018, 08:38   #32
turbobrick240
turbobrick240's Avatar
That mb 229.51 5w-40 will be just fine for the remainder of your ownership. The point about 504 is that you won't find a 504 spec oil that isn't also 507 spec- they are all 504/507.
Burning Oil 2015 Tdi Tdi2015 VW MKVI-A6 Jetta Sedan (~ 2011+) 6 December 29th, 2017 11:50
TDI burning oil mgblanke TDI 101 3 April 17th, 2014 13:24
01 jetta tdi burning oil + oil in air inlet tubes .. jettacaper VW MKIV-A4 TDIs (VE and PD) 3 September 26th, 2011 17:58
oil burning 96 TDI Help? Joe Bitsko TDI 101 2 July 14th, 2010 03:39
Oil additive for oil burning TDI speedR Fuels & Lubricants 15 November 1st, 2005 19:30
Page generated in 0.11082 seconds with 12 queries
[Output: 53.81 Kb. compressed to 49.80 Kb. by saving 4.01 Kb. (7.45%)]
