P0571 Brake light switch code Glow plug light flashing
andoo
St Albans VT
2001 Jetta
Ok so I hooked up VAG-COM and went to #6 and found that the clutch shows depressed no matter what I do, I shorted the two wires to the clutch switch still showed depressed. Dont think the switch is at fault here. Next step??
andoo
St Albans VT
2001 Jetta
Solved the mystery, found fuse #43 to be burnt out. One new fuse and everything is ok. Guess the question is, what's on that circuit that could cause the fuse to blow.
