jesus_man
- Joined
- Nov 9, 2005
- Location
- PNW
- TDI
- 2005 Jetta (gone), 2002 Passat (gone), 2009 JSW (VW bought), 2010 JSW
I did some searching and I think I will be replacing all parts associated with the sway bar (bushings and end links), but wanted to pose a question in case my issue is deeper.
I hear rattles from the suspension on nearly any undulation in the road. I found some slight movement in the upper joint of the passenger end link. Drivers side seems tight. This is with the tires hanging while the sub-frame is on jack stands.
My question is, with spirited driving around a corner, the suspension feels as if it hops and this same rattle occurs. The tire seems to even lose contact with the road as the car seems not to hold the line.
Do you believe I have more issues? What else should I check and how is it done? Thanks!
