Old April 21st, 2019, 17:04   #1
kwiatekch
Default 2015 CR Passat TDI HELP ME OUT !!! 6mt short gears
gears in my car got extreamly short !!! in addition car feels like if it had no balls !!! this is insane ! I made a video ! my car has next to no torque ! each time I get up yo 2k rpm it feels as if I was going 4k ! car has not even 40k miles on it ! and Malone tune - stage 2 (I re read file of from my car and support told me that everything checks out )
Ive also contacted geniuses from Alientech ECM Tuning only to comfirm what Malone support already told me !
https://www.youtube.com/watch?v=ojAgZMA13nc
PS. it is not that i cant get it up on higher RPM just that one time I drove in rain on highway and going 70mph on curve my rear tires slipped !!! i had my heart up my throat car has next to no traction it is just a nightmare !! anyone else had that problem ?
kwiatekch is offline   Reply With Quote
Old April 22nd, 2019, 05:02   #2
Smashed Ixnay
Kinda looks like same issues I had, which turned out to be an electrical issue. You can check my post history, but I just got my car back Friday. The only difference I can see is you don’t have any lights on your dash like I did.
They did a lot of “fixes” on my car before correcting it. I do think they fixed it this time, but I really need to wait a week of driving it since I’ve gotten it back before and had issues a few days later.
VWoA paid for everything.
https://youtu.be/GAaySoQuxa8
Smashed Ixnay is offline   Reply With Quote
Old April 25th, 2019, 01:51   #3
kwiatekch
Thumbs up what what
Do you know what was the problem ? what have they replaced ?
I have a manual transmission and honestly i feel like puking when im in 3rd gear driving 25mph !!!
before I took my car for airbag recall I wouldnt even switch to 2nd gear until 25-30rpm !!! today I pulled plug off from air flow sensor while running to see if it responses at all and I got that same ignition coil light you have flashing on your dash ! it came off after I connected the plug but I dont have a check engine light ! Later on when I get a chance I plant to connect VCDS and check values it reads ! but something tells me it might be a crank sensor seriously IDK man have to start checking just hoped someone on here would already resolved that problem though thanks for fast reply
what MPG are you getting ?
Old June 24th, 2019, 21:17   #4
gailjacobs
TDI(s): 2001 Jetta
Thanks for the thorough explanations
gailjacobs is offline   Reply With Quote
Old June 27th, 2019, 16:08   #5
KERMA
KERMA's Avatar
Sometimes tuners will disable the ability to show a check engine light so that they have fewer support calls or complaints. (Out of sight out of mind I guess, but this also frustrates diagnosing problems at times.) I would write the stock tune to the car, and see what codes show up. If it runs better stock, then talk to your tuner. If not, time for the dealer.
If you get a chance to scan codes, post the txt file that VCDS creates when you "save codes" and read the codes in the engine module, not generic OBD
HP is for show, TQ is for go.
celebrating http://www.kermatdi.com since 2002
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
First Road Trip 2015 Golf TDI 6MT alext91 TDI Fuel Economy 6 October 16th, 2018 07:30
FS: 2015 gsw tdi sel 6mt andytoby TDI Cars for Sale/Wanted 0 April 18th, 2018 11:26
FS:2015 TDI GSW 6MT:Indiana GIDDY_UP_GO TDI Cars for Sale/Wanted 12 September 18th, 2017 06:40
FS: 2009-2015 MK6, MKV,Golf,TDI, R32, Passat:DG Short Shifter,Panzer Plate-Tomball TX '12TDIJetta Private TDI Items for Sale/Wanted 2 October 19th, 2015 13:42
Need info on gears for TDI 6mt tranny 4motion prestipresse TDI Power Enhancements 9 March 2nd, 2010 20:34
Page generated in 0.14563 seconds with 12 queries
[Output: 70.77 Kb. compressed to 62.84 Kb. by saving 7.93 Kb. (11.20%)]
