99anSmokin
I know there is tons of threads about this but i cant seem to find the answer to my question. 2009 Jetta Sedan. Had soppy wet passenger floorboard, pulled seat, carpet, and mat out to dry. Poured water down front right drain and water poured in from the right "kicker panel". Tried weedeater line down sunroof drain multiple times to get stuck at the same spot. Took out front inner fender, lots of debris, removed wipers and windshield trim. Cleaned drain nipple and tried running line up through the drain and only made it about 4 inches. Water now drains fine...my question is, is there some sort of connector from the sunroof drain tube and the drain nipple thats keeping me from running line all the way through? Main worry is if there is a connection there it could be loose.
