tristan21
So as the title implies, I’m going to be doing an engine swap I’m my 1954 dodge pickup. I’ve already swapped the body into a 2000 s10 Frame. My question is which transmission is ideal in the rear wheel drive application? I drive mostly highway so mileage is key but I don’t want it to be a dog when I take off. Any ideas?
I plan to swap the rear end for one from a Ford Explorer for needed width. I haven’t yet decided on a transmission or gear ratio because I am not sure what I can use for a trans.
And secondly, I’m curious what type of fuel system do I need? Can i use the s10 fuel tank, pump and sender?
