I would recommend that when you break loose the harmonic balancer bolts, you turn them only 1/4 turn or less. Seems to me they work loose a little better if you get all of the m a little loose at the same amount. Why? I'm not sure but if I don't do that, at least one of the bolts will.not.come.out. And I end up using one of the Irwin sockets mentioned above nearly every time. They work on the valve cover allen heads as well. Not the same socket of course, but the same type. It is just trickier getting the ones under the intake manifold loose since you have so much less room there.
Good luck,
PH
