Tylere543
I have a 04 BEW, wasn’t running. Got PD150 injectors, new harness and cam sensor. Right after I installed the injector engine crank within a minute of priming and ran fine and then after about 2 minutes then car dies like it was starving for fuel. Engine will not start now. Has new tandem pump and lift pump. Timing was good unless it jumped. I’ll check tomorrow. Any other suggestions? I finally got it running again after about 30-45 secs of cranking running really rough and puffing blue smoke out and then died.
