Manual transmission fluid change
ianmac23
Ohio
MK5 Jetta
Hello I am new the club of owning a TDI. I purchased my 2006 Jetta a few months ago. Since owning it I have changed the oil, fuel filter, air filter and over the weekend I flushed the brake fluid and changed the transmission fluid. Before the change reverse was hard to get into and when it was really cold 3rd would give me issues too. After the change I adjusted the shift cables and now it shifts and the clutch engages like a new transmission. My concern is around the amount of fluid that came out of the transmission. I had the car jacked up in the front and then had it level and only got 24 ounces of fluid out of the transmission. I put 24 ounces back in through the reverse sensor hole. How do I know that it has the correct amount of fluid in the transmission? I am looking for advice.
Thanks Ian
Col Sanders
Illinois
97 B4 Green And it's Possessed 2001 Audi A4 AFN SWAP
Trans should hold about 2 qts. Bend a little wire and stick in fill hole. Should be just below the lip. Use the fill plug hole. Not the reverse sensor hole. Are you sure you took out the correct drain plug ? Just some things to check.
Henrick
Ireland
Golf VI TDI, 77 kW (CAYC)
Col Sanders, this is false.
OP, when draining the trans fluid, you should lock the selector fork in home position and then undo the drain plug. After that, remove the pivot bearing pin, more (dirty) fluid will come out. Install the pivot bearing pin and drain plugs back, remove reverse light switch.
Pour 1.9 L - 2.0 L of fluid back to the trans. Put the switch pack in. Unlock the selector mechanism. You are good to go.
Overfilling the trans by a little bit (50 ml - 100 ml) will do no harm to it. Underfill might a bigger problem, especially for 5th gear.
As the fill plug in the trans is in wrong position, the correct fill procedure is only through the reverse light switch. There was a TSB released by VW on this.
ianmac23
Ohio
MK5 Jetta
I did not do the pivot bearing plug because I did not think very much fluid was behind it. Do you think that is where the rest of the fluid was?
Henrick
Ireland
I'm sure. When I did the manual trans fluid service on my previous Mk5, even more fluid came out of there than from the drain plug. And besides, the fluid from the drain plug was more or less gold in color (~90k miles on the clock at that time), the fluid from pivot bearing was almost black.
ianmac23
Ohio
MK5 Jetta
Interesting thank you for the information.
lmoretti
Madison, WI
2006 Jetta TDI 5sp Manual
How often should the Manual Transmission Fluid be changed? I don't remember seeing that on the Service Interval sheet (only topping it off).
I've go an '06 with 105k on it and I'm not sure it's ever been changed.
Henrick
Ireland
According to VW, never.
But if you decide to do that, use genuine VW fluid.
Mine at 90k miles looked a bit exhausted. However, my car had hard city miles, average lifetime speed was like ~30 km/h, lots of idle time, constant shifting on 1-2-3, no highway driving.
Mad_Max
Lexington KY
'06 Jetta 5sp
I'm on the same boat with a lot of city driving.
I do all my maintenance myself, so ~$28 for 2 liters of the VW trans fluid is a "cheap" insurance.
At 90K miles I already done it twice. I know that is an overkill, but I had access to the gearbox already. First time at ~50K I was chasing the coolant leak and second time at ~90K was swapping a clutch to a SMF setup. So it was an extra ~10 minutes (if that) to get it done. Like I said "cheap".
Max
turbobrick240
maine
I did mine at 120k miles. It was still golden and looked great for that many miles.
Turfguy
Ohio
2000 Jetta TDI 5 spd / 96 Passat TDI (sold)
Do the mk4's have a pilot bearing that holds more fluid?
Also, what is 'home' position on the shifter- is it neutral?
Henrick
Ireland
Home position is not neutral. You place the trans in neutral and then slightly press the selector down. While slightly pressing it down, turn the plastic arm up 90 degrees. When it's pointing up, it's the home position.
Is it a bit more clear now?
narongc73
VA/OH
2006 Jetta TDI
Sorry to bring this thread back but I'm confused. Do we measure the oil that came out and put that amount back in? Bentley says to put 1.9 back in, nothing about measuring. Also said to fill thru backup switch.
scurvy
Good Ol' Boy
Chicago IL USA
2006 Golf
No, follow the linked procedure for draining the transmission (including the pivot bearing pin). Then refill the transmission with 1.9 - 2.0 liters thru the reverse switch.
Measuring only means you'll put back in the same amount that came out, which very well could be too little.
narongc73
VA/OH
2006 Jetta TDI
My issue is I drained it cold since the tranny is out of the car. I only got 1 quart out. I did follow the tsb. I put back 2quarts. Then I went and googled and found that people said to drain it hot, and someone drained 1.5 after waiting 2 hours. I just put the plug back in when the drip slowed. I'm thinking it's overfilled by a quart. Should I drain some out or leave as is?
Henrick
Ireland
Draining it with the car out of car might have caused the issue because the trans was not level. If you lose sleep because of this, you can go ahead and repeat the procedure. Don't forget the pivot bearing pin. Let it drain completely (~1-1.5 hours, while having some beer). Then put 1.9-2.0 liters back through the reverse light switch.
