View Poll Results: Which AMSOIL?
Premium API CJ-4 Diesel Oil (DEO) 100 28.25%
European Car Formula Motor Oil (AFL) 254 71.75%
Voters: 354. You may not vote on this poll
Old August 25th, 2006, 11:32   #181
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
Originally Posted by GoFaster
The issue with Amsoil (in general) is that Amsoil themselves say that it meets or exceeds whatever standard you are talking about (505.01 in this case), but they have not gone through with the actual approval process to INDEPENDENTLY CERTIFY that it meets that standard.
VW publishes a list of oils that VW has approved against the 505.01 standard. There is no Amsoil oil to be found on that list.
That is different from saying the stuff is no good. But what it means is that IF something lubrication-related goes wrong, VW is not going to support warranty coverage on the grounds that you did not use oil that was officially approved to the 505.01 standard. Which means, you are going to have a battle on your hands.
There's the info the way I see it. Now it's your choice.
But AMSOIL WILL either warranty the engine on its own, or do the battle for you with VW to get it warrantied
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old August 25th, 2006, 14:11   #182
tdi06
C'mon guys, cut all the crap. He asked a specific question about Amsoil 3000 and not for your views on using 505.01 oil or having it changed at the dealer or the warranty. Lets stay focused here and not turn this into a million post thread filled with nothing but opinions. A simple no would suffice.
tdi06 is offline   Reply With Quote
Old August 25th, 2006, 14:23   #183
milehighassassin
Fuel Economy: 43
Originally Posted by milehighassassin
So no you cannot use Amsoil 3000.
Old September 22nd, 2006, 06:30   #184
TwoSlick
Default Amsoil 5w-40, CJ-4
Spoke to Amsoil tech services about this product, due out on 1 October. Looks like pricing will be the same as their 5w-40/VW 505.01, European oil, or a bit less than Delvac 1. Product will be available in quarts, gallons and 2.5 Gallon jugs.
This would be a better choice for older (non-PD) TDI's than the European 5w-40, since it's about 15% thicker in terms of high temp, high shear viscosity and it has higher levels of AW additives (zinc/phosphorus).
This should be a CJ-4/SM rated formulation, it can also be used in all modern gas engines if you'd like to simplify your life...
TS
TwoSlick is offline   Reply With Quote
Old September 22nd, 2006, 08:04   #185
d2305
What about running it in PDs? I'm using the european formula now, and the UOA have been less than optimal.
d2305 is offline   Reply With Quote
Old September 22nd, 2006, 08:24   #186
wjdell
Fuel Economy: avg. 41.93 high 46.32 low 34.6
Those less than optimal UOA's on AFL - are they posted. What was the milage, 5k 10k.
AMSOIL has two different 5W40 ?.
Post your UOA data in the TDI UOA Database thread
http://forums.tdiclub.com/showthread.php?t=205814
~ USED OIL ANALYSIS ~ http://forums.tdiclub.com/showthread.php?t=190958
1.9 PD Jetta V ~ pkg 1 ~
DSG ~ 17" VV ~ 36/34 psi ~
ULSD ~ DG-BP90 - speed 39.2
hwy/city 83% / 17% ~
elev 58 ft / temp 72 F / humidity 76% ~ MPG 48.3 / 42.8 / 35.6
wjdell is offline   Reply With Quote
Old September 22nd, 2006, 09:17   #187
TwoSlick
The additive chemistry is a variation of what Amsoil is using in their VW 505.01 oil. I don't think there would be a problem running this new 5w-40 in the PD's, but it's not explicitly recommended for that application. I'd wait and see how it does in older TDI's and then decide. The fact that's it's significantly thicker than the 5w-40/AFL product should reduce valvetrain wear. Howeve this is still an 8 TBN formulation, so I wouldn't necessarily expect it to last longer in service.
Yes, Amsoil will have two different 5w-40 in about two weeks, but there is a lot of overlap with these two oils. The basestock blends and additive chemistry looks very similar to me. The CJ-4 stuff simply has a higher additive treat rate of the same chemistry as the VW 505.01 product. Of course the CJ-4 stuff does have to meet all the HD engine sequence tests, so from that respect it may be a superior formulation.
TS
Old September 23rd, 2006, 14:23   #188
wjdell
TS were you get this data - can we compare to AFL for oursleves.
Old September 23rd, 2006, 15:24   #189
AndyH
Default AMSOIL CJ-4 5W-40 (DEO) Datasheet
Here's the pre-release datasheet for the new 5W-40 that will hit the streets on 1 Oct.
AndyH is offline   Reply With Quote
Old September 23rd, 2006, 17:07   #190
wjdell
This would have been the best choice for my Lambardini - and I could use in my Kubota. Wish I had known, I would have waited to order this. Does look a tad thicker than AFL.
Old September 24th, 2006, 11:03   #191
TornadoRed
TornadoRed's Avatar
TooSlick, do you sense any 'resistance' toward the CJ-4 rated motor oils? Or, to put it another way, do you believe there will be any hoarding of CI-4 and CI-4 Plus oils?
'03 Golf with 741k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Blizzaks, TDT or Delvac1
Like TDI Club? Got PayPal? Got $1 or $5 or $10? Contribution link on the main page.
Old September 24th, 2006, 13:23   #192
AutoUnionTypeC
AutoUnionTypeC's Avatar
A couple of questions if you don't mind. Firstly please define what year range you consider older, does my 2000 ALH fall into this range? Do you also feel this is a better choice then the VW spec oils 506.01 and 507.00 that are 0w-30 and 5w-30? Lastly, can you tell me whether Amsoil makes its own base stock, if not from whom does it purchase?
Regards
2000 New Beetle TDi
Kioti CK20 TDi
AutoUnionTypeC is offline   Reply With Quote
Old September 25th, 2006, 15:09   #193
bowlerman
Default synthetic 10w-30 amsoil?
anybody use this, i bought a case because my lifters started tapping and was going to put thicker sythetic in there? anybody use it or like it?
bowlerman is offline   Reply With Quote
Old September 25th, 2006, 15:51   #194
Drivbiwire
Zehntes Jahr der Veteran
Wrong oil and the fact is the 10w30 flows WORSE than ANY 5w40!
DO NOT USE IT! Only use the Amsoil 5w40 AFL which is approved for the TDI motors.
DB
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old September 25th, 2006, 23:22   #195
Fortuna Wolf
Fuel Economy: 36 mix
That's a graph of it at start up, I assume?
You could get away with using it with a preluber, but a preluber would probably solve your problem anyway. A 0W lube would be better.
2002 Jetta Sedan ALH-01M: 2 um Cat FF, Wingnut-3 CCV filter, polyurethane fuel lines, 5 brake light mod, Ventectomy, Polysiloxane vacuum tubing, Pioneer DEH-3800MP w/ KFC-1389ie, Panzer Plate, EGT+Boost+Oil Temp Gauges, Boost Valve, KERMA Line Pressure Mod, LED Lighting, HC-12a refrigerant, Optima 75/35 AGM, .187 nozzles, Hawk HPS pads.
Coming Soon: ESP retrofit, Custom Greasecar.
Wish List: Tow Bar, DSG or CVT transmission, or even a 5 speed manual. To hit 42+ mpg
Fortuna Wolf is offline   Reply With Quote
Page generated in 0.19927 seconds with 11 queries
[Output: 132.13 Kb. compressed to 111.20 Kb. by saving 20.93 Kb. (15.84%)]
