AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
I'd have your shop guys to drain the oil down near proper level. But, being a quart over full is no going to kill anything. There will not be any aeration either. If that was an issue, the fact that the oil pump chain driven sprocket is located down in the oil pan would mean loads of "aeration" at almost any oil level on the dip stick. Also, keep in mind, the oil being slung out from around the rod and main journals is being slapped by the crankshaft, etc., thus no aeration. And, the oil sprayers shooting oil up on the bottom of the pistons do not cause oil aeration. The vast major of flying oil and drain-back from the head is caught by the windage tray which returns it to the oil pan..... Oil aeration resulting in foam/bubbles in these engines is nothing but a myth, in my opinion
I bet the squeal/whine is an exhaust leak as others are saying. If the sound tends to change and/or go away as the engine warms up, that would be an indication of sealing off by heat expanding the various metal/materials involved.
Revving the engine with no load doesn't create much boost at all ...... prolly less than 1 psi.
