Jesse_Boyer
(no help in the vehicle specific forum, so I'm going to try here as well.)
My wagon recently developed an excessive smoking condition at anything above 75% throttle. After having my Malone tune installed nearly a year ago, I didn't notice anything like this. Over the last month or so, I began to notice this; new condition. I even swapped to a generic set of 0.205 injectors just to test and the condition doesn't get any better vs my PP764's.
I logged timing, actual and requested, and while actual does seem to track somewhat, I noticed at idle jumps all over and hits 0.0° often. This was just watching the two numbers on basic values. When watching those two items graphically via advanced measurements, the actual seems to stay at/near 0.0° BTDC and the requested is pretty constant at 3° BTDC (where I have it set.) (edit: days later, I noticed the actual timing appears to be stuck at 0.0°, not moving at all at idle, not trying to achieve the requested set point. The cold start valve indicates 44.4% for the most part unless its rev'd and then it'll only move slightly, but doesn't track requested much at all.)
IQ on the 764's was previously set at 6.5-ish and it didn't smoke this bad initially after the tune, now it does. Now I have the smaller 0.205's in and set at 6.0-ish and they smoke quite a lot.
I also logged boost pressure and actual almost always closely meets requested. Vacuum lines are all new, vanes are not stuck at all, move very freely. I don't think its a boost issue.
Does anyone think it might be anything other than the N108 valve which controls pump timing? I tested the resistance and this measured in the 'normal' range of 16.9ohm, but if the pump is really injecting at 0.0° BTDC... there would almost certainly be excessive smoke.
I've played with the wiring trying to get a reaction out of the N108 valve hoping to find a short in the wiring, but I can't see anything abnormal for at least 8" of chassis wiring. The wiring from the N108 valve to the pump plug looks normal too. However, when testing it, it definitely delivers an acceptable resistance as mentioned.
Any help is greatly appreciated.
PS: no fault codes.
PS: no fault codes.
