Hey guys so I'm new to this forum but Im not new to the 1.9 l TDI engine, but this one has me stumped. I bought my 2001 vw jetta about a yr ago and decided to upgrade the engine a bit to get some more power out of it. So I went ahead and deleted the egr. Straight pipe, and next I decided to change the injector nozzels. So I took all the steel lines off, return lines, glow plug harness and removed all the injectors. Of course they were seized in so I had to make my own tool out of a slide hammer. I changed all the nozzels and installed new copper washers. Put everything back together and when I went to bleed the steel lines all I'm getting is a bubbly froth. So I checked my fuel filter and noticed it was half empty. So I got my electric pump and bled the line coming from the tank untill all the air was out. Then I went to bleed the return line coming out of the IP and I sat for about 20 min and nothing. Checked all the lines and connections and no leaks. So for fun I tried my hand vancum pump. And as soon as I pulled the handle it sucked right back in on me. Its like i cant suck anything through the pump. So either I have a blocked line or something I dunno. Any ideas ?
