pbraunton
Hello all Ontariarians!!!!
I have been having a hard start issue just as winter is beginning to break, not to say my car wouldn't start it was just taking a few seconds longer than normal.
I initially thought it was caused by a bad glow plug i had but once i replaced the plug it has not went away, and it is still there now that it is warmer out, .........
so i thought i give her a scan, nothing came up except the antenna, which i have soldered to bypass the electronics in the base, and knew it would come up,
i checked the timing after i got home form work the other day, and it is down to 39, fuel temp was 110, ...........so this is retarded.......
I have a few questions:
would the retarded timing be the cause of my "longer than normal" crank time??
and I know how to adjust the timing from reading the how-to's, but would anyone be willing to assist/show me how to do it?
to be honest anything with timing, or the timing belt scares me, .......but i would feel more comfortable doing it with someone who has done it before, ......i've done the clutch, brakes, and going to be replacing the entire suspension in a couple of weeks, but timing stuff I am unsure about!!!!
I can meet at your place or you can come to mine?, I live in Innisfil, work in Mississauag, and I am pretty sure i have all the tools to do the job, (i assume it is wrenches and VCDS, nothing out of the ordinary)........
in exchange i will offer what i can, which off the top of my head would be to read your ECU for your SKC so if you loose a key you can re-program your own with VCDS???
thanks for your help and your time in reading this,
please PM me, or email pbraunton at g mail dot com
