2006 Jetta TDI 5sp, abt 46,000 miles
Ok, so I get the idot 'Light out' warning light... so I run a VAG-COM Scan and get this..
Address 09 Cent. Elect.
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
1 Fault found:
00987- Lamp for Brake Light; Left (M9)
012- Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault priority: 1
Fault frequency: 1
Reset counter:95
Mileage: 75334 km
time indication 0
Freeze Frame:
:ON
Voltage: 13.20 V
:ON
:ON
:OFF
:OFF
:OFF
That was the readout after I reset the codes the first time
the first readout was similar except with lower mileage and a higher voltage (14.10V) first time.
any suggestions? The brake lights, turn signals, and flashers all seem to work fine.
Thanks in advance
1 Fault found:
Freeze Frame:
Fault priority: 1
Fault frequency: 1
Reset counter:95
Mileage: 75334 km
time indication 0
Freeze Frame:
:ON
Voltage: 13.20 V
:ON
:ON
:OFF
:OFF
:OFF
Thanks in advance
