QR12
Hello, i have a 2004 passat tdi 2.0L BHW that i bought not running. It has 150,000 miles on it and it has been serviced regularly. The previous own said they where driving it one day and it just shut off. I change the ecu and it starts now, but idles very rough, almost like it is missing, and when you put it in gear it stalls. I checked some stuff with VCDS and there are no fault codes. I checked cam timing also and it's at -0.5, which i was told was fine for this engine. Does anybody know what is wrong or what i should check?
Thanks!
Thanks!
