Old February 18th, 2013, 00:06   #16
mk1-83
Fuel Economy: 1:15
228mm
Lupo 1.9 tdi
H-beam, 1:17 cr, 12mm pump,dss-r.360,gtb2365 vklr.
300+ HP 500 nm
https://www.youtube.com/watch?v=1h3bxhWZcvk
mk1-83 is offline   Reply With Quote
Old February 18th, 2013, 01:11   #17
eddie_1
eddie_1's Avatar
Even with Southbend Stage 2 Endurance it broke my tranny, which is the next weak link. So on a stock Tranny it doesn't make much sense to go above that anyway, unless you want to baby the car.
2008 A6 BPP 267kmh also 283kmh 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old February 18th, 2013, 07:47   #18
How did you manage that?
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old February 18th, 2013, 07:58   #19
eddie_1
eddie_1's Avatar
Hi Peter, I floored on the Autobahn merge in 5th like my 150mph video one too many times. You know the 5th is a weak link and deWitt has a mod for it. Not sure how good the mod is, but the 02M DRW is built like a tank. Probably one of the best trannies built. The shifter linkage apparently has some weakness with rivets but I am gentle with it.
Old February 18th, 2013, 08:34   #20
You're right, 5th seems to be a weak link. A colleague here who doesn't drive hard at all just stripped his 5th gear. I've been mystified as to why I haven't had this problem until I realized I never drive the car hard in 5th. On the track I'm in 3rd and 4th all the time, and I haven't tried any top speed runs in a long time. I can get 120 MPH out of 4th anyway.
Old July 13th, 2017, 18:26   #21
06jettatdi89
Default 2006 vw tdi 1.9 5spd Jetta
Hey guys I'm looking for info. My car started making a ticking noise around the transmission and engine but only when 1500rpms or higher and it felt like the transmission or clutch slipped just one time before I got it off the road. It is leaking oil but only when I drive it(didn't drive it very far). It smells like burnt transmission fluid(my thinking is is getting on the clutch which is burning it maybe) but it moves in every gear and clutch still seems to work. I'm thinking that part of the clutch broke which was what was making the ticking noise and that the part that broke took out a transmission seal but I'm not 100% sure. Just wanting to see what other people think if that's a possibility or not
06jettatdi89 is offline   Reply With Quote
Old July 14th, 2017, 14:47   #22
KERMA
KERMA's Avatar
The best clutch is always whatever that particular vendor is selling.
just want to point out... Every product inevitably has "issues" whether caused by the product or user error or abuse or whatever. The more popular it is, the more likely there will some complaint or other, whether it is justified or not, for whatever reason. You don't always get a full picture from rants on the internet.
So when you see "I've never heard anything bad about so-and-so" there's a good chance that there simply aren't many (or any) of them being used. Just saying
HP is for show, TQ is for go.
celebrating 15 years of: http://www.kermatdi.com
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old July 17th, 2017, 08:45   #23
carsaremytoys
My VW guru mechanic runs a 12.30 1/4 mile on the stock luk clutch
carsaremytoys is offline   Reply With Quote
Old July 17th, 2017, 20:00   #24
Rrusse11
My guru reckins it's better to have the clutch slip rather than break the gearbox.
RC Stage 4: 11mm pump, 17/22, 3bar MAP:2.5" Exhaust: Koni Reds HD Springs, ~1"lift:VR6 fr swaybar, Top strut & rear tie bar: XXIO Racing Rims, 215/55ZR16 GMax AS03's, 10mm/20mm spacers, 35# @: Ventectomy: Atlas skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: Bosal Hitch: VW racks:
Rrusse11 is offline   Reply With Quote
Old July 17th, 2017, 20:16   #25
carsaremytoys
It it slips and gets him through the 1/4 at 12.30...
Old January 8th, 2018, 21:05   #26
Justin S
Default Clutch Problem
I recently put a new clutch kit in my 2006 Volkswagon Jetta TDI. Ever since I put it in, it shakes taking off (Like your in to high of gear) but rpmís donít drop. It has been doin this for a couple months although it hasnít hurt anything I was just wandering if anyone knew why it did this, thanks
Justin S is offline   Reply With Quote
Old January 9th, 2018, 05:33   #27
Mongler98
depends completely on the application. if you want a daily driver out of it with fairly the same clutch feel, south bend clutch endurance clutch is really good, it holds up to anything i can throw at it.
Clutch Release Lever Failure - Clutch/Shifting Problems Fixed sullyTDI TDI 101 9 January 18th, 2017 15:02
Replaced entire clutch system, now no start. Suspect clutch sensor. saucer VW MKIV-A4 TDIs (VE and PD) 10 October 6th, 2012 13:57
Replaced DMF clutch - now makes whooping noise when clutch partially depressed RickandJules VW MKIV-A4 TDIs (VE and PD) 12 July 30th, 2010 17:41
clutch spec 2 difference not the regular clutch question please read asap BlakGolf Upgrades (non TDI Engine related) 13 January 20th, 2006 07:46
Clutch shudder a while back, now clutch slip. DBW: Upgraded DMF an option? InDiesel Exposure VW MKIV-A4 TDIs (VE and PD) 3 October 25th, 2002 21:54
Page generated in 0.11722 seconds with 13 queries
[Output: 111.12 Kb. compressed to 94.12 Kb. by saving 17.00 Kb. (15.30%)]
