Old June 30th, 2017, 07:10   #1
ACMTDiJet
Fuel Economy: About 45(im not very gentle)
Default 2004 passat gear ratio fault.
Good morning tdiclub. I have a bhw passat with a gmr auto. I know these things are pretty much known for failures however im more interested in the diagnosis portion. The car has almost 270k. I dont know if the gmr is OG or not but heres the skinny.
Had P0741 so i know it needs a TC.
Then tiptronic stopped working.
Now in limp mode with PRND432 lit up with gear ratio monitoring and excessive clutch slippage faults
Now im not looking for someone to say "Trans is junk" cause im already gonna replace it with a new TC. The wife likes it to be automatic so no manual swap.
I am curious on how to determine if the gear selector module is bad as well since tiptronic hasnt been working. Checked under the pass. carpet and found no water damage or broken or bad wires and the TCM was sealed up good. Any help, advice or overall sympathy would be much appreciated.
ACMTDiJet is offline   Reply With Quote
Old July 7th, 2017, 11:00   #2
suncoug
In the interest of saving time and your sanity, I would assume the worst, which is the most likely scenario. Your option is to either replace it with a factory reman. auto or a manual swap. It may cost at least $5k, unless you can do the work yourself.
There is no easy or cheap option with these cars.
suncoug is offline   Reply With Quote
Old July 8th, 2017, 06:19   #3
TheGrove
So prior to the transmission dying the selector worked fine except for the tip side, correct? If so then I saw a post sometime ago that there are magnets or such on that side of the shifter that sense when the handle is moved. If you can find that post it explains how to fix them.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old July 13th, 2017, 12:32   #4
d0u8l3m
d0u8l3m's Avatar
TDI(s): B5.5 Passat
If you need a good working auto lmk im getting my manual swap done soon
d0u8l3m is offline   Reply With Quote
Old July 16th, 2017, 11:11   #5
ACMTDiJet
Thanks everyone, i got a used auto and TC with 6 month warranty for 2k and installed it with new bolts, the whole nine. Test drove. Constant p0741 and incorrect gear ratio in every gear. Once im done ripping my hair out ill be figuring out another plan.
Old July 16th, 2017, 11:17   #6
ACMTDiJet
Appreciate the help. After i replaced trans and TC still not tip. Assuming its broken somehow. Ill look for tje post, thanks
Old July 17th, 2017, 04:15   #7
TheGrove
See this thread (http://forums.tdiclub.com/showthread...ghlight=magnet) starting about post 9.
I also found this (http://www.passatworld.com/forums/vo...ssat-audi.html) on another site, unfortunately the pictures are gone.
what 5th gear ratio is in the 2005 Passat TDI automatic? nvr-enuf VW B5 Passat TDIs 33 March 1st, 2015 14:02
FS: 0.744 ratio 5th Gear Set from 2004 Jetta TDI (BEW) algirdas Private TDI Items for Sale/Wanted 7 May 29th, 2014 19:05
Golf TDI gear ratio vs. JSW gear ratio (USA Manual ONLY) nj1266 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 18 April 19th, 2010 10:36
Passat 5th gear ratio incorrect in Bentley Chris Bell VW MKIV-A4 TDIs (VE and PD) 4 February 9th, 2002 05:27
Is there a higher ratio 5th gear available for the B4 Passat TDi? Metalnerd TDI Fuel Economy 5 January 5th, 2001 11:00
Page generated in 0.15982 seconds with 13 queries
[Output: 80.54 Kb. compressed to 70.25 Kb. by saving 10.30 Kb. (12.78%)]
