Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old July 14th, 2017, 18:03   #1
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Default Study: Modern diesel cars emit fewer carbonaceous particulates than gasoline cars
Study finds modern diesel cars emit fewer carbonaceous particulates than gasoline cars
A new study by an international team led by researchers from the Paul Scherrer Institute (PSI) in Switzerland has found that modern diesel passenger cars equipped with diesel particulate filters (DPFs) emit fewer carbonaceous particulates than gasoline-powered vehicles. The open-access study is published in the journal Scientific Reports.
They found that emissions from new gasoline cars (both EU and US) produce up to 6.5 times more SOA than POA after 5–10 hours of atmospheric aging. New diesel cars produced no detectable SOA, contrasting with old diesels, for which SOA production is about equal to emitted POA.
Old July 15th, 2017, 08:08   #2
john.jackson9213
TDI(s): 1996 B4V
FAKE NEWS!! :d
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old July 15th, 2017, 09:49   #3
tadawson
Why do you say that? This conclusion seems pretty obvious from here . . .
tadawson is offline   Reply With Quote
Old July 15th, 2017, 10:19   #4
flee
Fuel Economy: 40-ish
In a related story: "Toothless dogs cause fewer bites than dogs with teeth."
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old July 15th, 2017, 11:14   #5
wxman
TDI(s): Other Diesel
This is another in a series of studies which support the premise that gasoline engine exhaust is largely responsible for SOA production in urban locations, and that exhaust from newer diesel vehicles is largely passive with respect to SOA precursors. Here are several other studies concluding that premise just over the past 5 years or so:
Bahreini, R., et al., "Gasoline emissions dominate over diesel in formation of secondary organic aerosol mass." Geophys. Res. Lett. (2012)
Nordin, et al., "Secondary Organic Aerosol Formation From Gasoline Passenger Vehicle Emissions Investigated in a Smog Chamber." Atmospheric Chemistry and Physics Discussion, 12, 31725-31765, (2012)
Gordon, et al., "Secondary organic aerosol formation exceeds primary particulate matter emissions for light-duty gasoline vehicles." Atmospheric Chemistry and Physics. 09/2013; 13(9):23173-23216
May et al., "Gas- and particle-phase primary emissions from in-use, on-road gasoline and diesel vehicles." Atmospheric Environment, Volume 88, May 2014, Pages 247-260
18th ETH Conference on Combustion Generated Nanoparticles, June 2014
Yunliang Zhao et al. (2016), "Intermediate Volatility Organic Compound Emissions from On-Road Gasoline Vehicles and Small Off-Road Gasoline Engines" Environmental Science & Technology
Gentner et al. "Review of Urban Secondary Organic Aerosol Formation from Gasoline and Diesel Motor Vehicle Emissions." Environ. Sci. Technol., 2017, 51 (3), pp 1074-1093
Yunliang Zhao et al. "Reducing secondary organic aerosol formation from gasoline vehicle exhaust." Proceedings of the National Academy of Sciences, May 2017
Regulators really need to start focusing more on NMOG/VOC emissions than NOx.
wxman is offline   Reply With Quote
Old July 15th, 2017, 11:23   #6
john.jackson9213
TDI(s): 1996 B4V
I was being sarcastic! Sorry.
But, flee got it.
Particulate filters for gas engines will be another cost push towards electric cars.
JJ
Old July 15th, 2017, 11:38   #7
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
I'm very much in favour of forcing particulate filters in any kind of combustion engine, Diesel or otherwise.
Old July 28th, 2017, 05:32   #8
Powder Hound
Powder Hound's Avatar
Fuel Economy: pretty freakin' good.
The only problem with a study such as mentioned above is that the regulators refuse to let facts get in the way of their own prejudices. They prefer to generate facts and only regard that such as demonize their enemies and support their friends.
This is just a verbose way of saying EPA, CARB, and such are not interested in the integrity their jobs should require.
Oh, well.
PH
Thinking outside the box is difficult for some. They're afraid they'll fall off the edge of the box and be lost to oblivion.
Powder Hound is offline   Reply With Quote
Old July 28th, 2017, 07:59   #9
tadawson
And I'm very much in favor of throwing over zealous regulators into volcanoes . . . Some regulation is good, too much is rarely better . . . :-) :-)
Old July 28th, 2017, 09:48   #10
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Smile
Agree 100%. Well said.
I will GLADLY take high NOx levels from an emissions cheating CR TDI while having significantly LOWER emissions in all other regulated emissions categories compared to any gasser.
David Sterrett, N1DAS
2014 BMW (F10) 535d XDRIVE M-Sport, 255hp & 413 lb-ft of AWD stomp 'n go fun!
2012 BMW (E70) X5 XDRIVE35d, 265hp & 425 lb-ft of AWD stomp 'n go fun!
Member SSBMWO
Why DIESEL is better:
http://webpages.charter.net/lmarz/emissions.html
http://webpages.charter.net/lmarz/efficiency.html
http://webpages.charter.net/lmarz/performance.html
http://webpages.charter.net/lmarz/emissions2014.html
http://webpages.charter.net/lmarz/emissions2016.html
n1das is offline   Reply With Quote
"The top 15 cargo ships worldwide emit more pollution than Earth's 1 billion cars" nicklockard TDI (Diesel) Emissions 82 January 20th, 2016 15:32
Do you hate the style of modern cars as much as I do? 2011tdiproject General Automotive 97 August 31st, 2014 16:30
TÜV NORD Study: Direct Injected Gasoline Engines Emit More Particulates Than Diesels rabid_chihuahua TDI (Diesel) Emissions 8 June 16th, 2014 11:33
Honda unveils diesel system to rival gasoline cars tditom Non VW Group Diesels 16 November 3rd, 2006 10:35
Diesel oil for gasoline cars konghh Fuels & Lubricants 3 June 24th, 2001 17:37
Page generated in 0.10576 seconds with 13 queries
[Output: 101.70 Kb. compressed to 86.94 Kb. by saving 14.77 Kb. (14.52%)]
