Hello!
My car has needed a jump start twice in the last couple weeks. The battery is only 1 year old, so I took it in to Walmart & they said it tested good. The battery was rated for 730cca, and was testing at 646cca. They put it on the charger & got it up to 681cca.
When I got home, I tested the voltage with a multimeter. With the car off, the battery tested at 12.67v (seems fine). With the car running at idle, it tested at 13.8v with nothing but the DRL on & 13.5v with the A/C blower motor on.
That seems a bit low. Shouldn't the alternator be showing more like 14v even under load?
Is it possible that my alternator is under-performing & should be replaced?
Any advice would be appreciated.
