I'm about to change my oil myself for the first time. I've read that the drain plug uses an Allen Wrench. This doesn't surprise me because old air-cooled VW's used a 17mm Allen Wrench to drain the transmission/differential oil.
I went ahead and bought a 17mm Allen Wrench at Sears. 17mm is the largest they carried, btw. But I think I read once where the oil drain plug is 19mm. So which is correct? And if it is 19mm, where can I buy a 19mm Allen Wrench? TIA
