richmondvatdi
- Joined
- Feb 5, 2005
- Location
- Chesterfield, Virginia
- TDI
- 2005 Passat Wagon 5-speed,2003 Jetta GL Wagon, 2003 Jetta GLS Wagon, 2013 CC 2.0T
I am in the middle of replacing the upper and lower seals on the oil cooler to stop a leak. I also bought the flange gasket (housing to engine block) and figured I'd go ahead and change it too while I'm at it. However, I looked at the Bentley manual last night just before pulling it off and was surprised to see that it says to replace those bolts. Although I don't have a problem buying new bolts, I don't have the time because my daughter is taking the car back home.
Have any of you replaced that gasket without replacing the bolts and were there any issues? I don't think that this gasket is leaking so I don't absolutely have to change it now. If it's risky to reuse the original bolts, then I'll just leave it for another time.
