Fix_Until_Broke
ABS Tone Ring was more/less a solid mass of rust. Attempted to clean it out and it ended up coming loose.
Figured I'd have to replace the whole rear wheel bearing (which is still just fine), but was pleasantly surprised to find just the tone ring available from idParts
https://www.idparts.com/abs-ring-a4-p-2317.html
Does anyone know how this thing is retained to the wheel bearing assembly?
Assuming I pull the rear bearing off (the old one came off in pieces) - just not sure what holds the new on in place so it doesn't move/spin/etc?
