Moonbaby
Hello everyone!
This is my first post here so please allow me to introduce myself. If you wish to get right to my concern then just scroll down..
I'm currently serving overseas in the United Kingdom and bought the wife a VW Passat 1.9L TDi (Estate model). I've posted on the UK forums for help and have gotten little to no guidance. Read up and down the internet for any possible solutions and all have not resolved my misfire even the slightest. So here I am asking for help!
Our Passat has a misfire but only at idle with no codes. Took it to our local shop and they recommended that they replace the injector's wire harness. About $200 later our problem still persists! They then told me that it'd be wise to just scrap the car and move on because the injectors might be bad. I simply thanked them and decided to take this problem on myself. Gathered from my reading I replaced the fuel filter, which has a fuel heater on top and has to be the dumbest setup I've seen yet, but that got us nowhere. Cleaned the MAF/AMM and any other solenoids I could get my hands on with no change.
So I went out and purchased a bluetooth/wifi OBD2 reader and it supported a few PID's that I could watch live but no injector readings or misfire readings of course. What I did notice was an overboost of 23psi when the wife gave it some gas and instantly engaged it's limp mode. Discovered a feint hissing noise of a vacuum leak from the N75 solenoid and read that it goes hand-in-hand with overboost issues. So I'm gonna tackle that problem and buy some new vacuum lines to replace these cruddy braided lines and hopefully eliminate any and all leaks. I'm also contemplating the cleaning of my EGR valve and intake manifold just praying maybe something that simple will fix our family car. (Side note: closing, or is it opening? Pushing the plunger/actuator all the way in on the EGR valve eliminates the misfire completely)..
**Cliff notes**
Engine misfires: replaced the injector wire harness, fuel filter, cleaned MAF, possible faulty N75 due to overboost, trying to isolate vacuum leak in that area. Shop can't tell me which injector or if it is the injector(s) that's causing the issue. Please help, I fix planes not cars.
P.S. I'll post pics for attention tomorrow when the sun comes up!
**Cliff notes**
