turbocharged798
This is on my BEW. A while ago the check engine light cam on and it threw a code for the turbo actuator feedback sensor. I cleared the code hoping it would not come back, but after 50miles the light came back on with the code.
Here's the code:
Just wondering if any of our gurus have seen this before.
Here's the code:
I guess I have to drop the belly pan and see what is going on. What are the odds the actual actuator is bad? I know you cannot buy them separately for the KP39 so I really hope it is not that!Sunday,13,March,2011,17:14:47:38256
VCDS Version: Release 10.6.1
Data version: 20100831
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 038 906 016 H HW: 028 101 114 6
Component and/or Version: R4 1.9L EDC G000SG 5375
Software Coding: 0150031
Work Shop Code: WSC 00066 000 00000
VCID: 192701CCA9EB
1 Fault Found:
18996 - Turbocharger Boost Control Position Sensor Circuit: Signal too Low
P2564 - 000 - - - Intermittent
Freeze Frame:
RPM: 1386 /min
Torque: 78.0 Nm
Speed: 21.0 km/h
Temperature: 4.5°C
Voltage: 14.36 V
Lambda: 100.6 %
Lambda: -7.6 %
Readiness: 0 1 0 0 0
