Old November 14th, 2017, 11:21   #1
bobbiemartin
Default ALH 250+ HP Internals
After reading and responding to some other threads here, I'm wondering what needs to be done to have a reliable 250 (or more) HP ALH. I'm pretty happy with my car now, but wondering what it would take to get a good bump in power. From what I've read, much over 22-24 pounds of boost requires stronger rods.
I'm just in the planning stage and I have a complete ALH engine I could use for the build. However, if I'm going to change the rods, what else should be done? I've read lots of threads, but not 100% sure what is the best way to go. As I understand it the BEW and ARL blocks are stronger. I know the BHW pistons are said to be the best to use. Can the BHW block be used with ALH accessories (head, front plate, pump, etc)? The BEW and ARL cranks have larger rod journals. Any appreciable difference between them?
I'm thinking the BHW or BEW block with BHW pistons using aftermarket rods with a ARL or BEW crank and ALH head may be the best combination. I would welcome any suggestions
bobbiemartin is offline   Reply With Quote
Old November 14th, 2017, 13:25   #2
sam-
If i were you i would just put rosten rods or any good aftermarket rods and eventually get the pistons machined to lower the CR.
But it look like many people push power on standard block, especially as the high powered one doesnt have much in the low rev, obviously a good tuning also help to keep everything in one piece.
sam- is online now   Reply With Quote
Old November 27th, 2017, 08:57   #3
MAXRPM
MAXRPM's Avatar
Fuel Economy: 57 mpg driving like a granny on HWY-5 from LA to SF
22-24 Lbs of boost will not get you there,, more like 35 lbs or more,, 250 HP on ALH needs a lot $$$,,,17/22 turbo I was able to max that sucker out at 220Hp,, if you want 250 you need to go with at least 17/56 VK or a bigger turbo, internals you would need rosten rods, big cam with a great lift, FMIC, 11 or 12mm pump, lift pump, 6 speed tranny, (stock tranny would be at the brink of failure) big clutch, huge injectors, bigger oil cooler. and a key ingredient bore the head, plus ram more air at air duct, then look for someone like RC for custom tune (best in the business period) to give you RC 6+ and you will be there ..
1/4 mile run----13.98 sec. @ 105.37 mph 8 years ago
I dynoed at 275HP at LCD back then, now 2.0 TDI with the real bolt ons, HP and TQ who knows???
MAXRPM is offline   Reply With Quote
Old November 28th, 2017, 22:44   #4
bhodgkiss
The OP didn't say 22-24lbs would give him his power goal; he was merely stating that he's heard that after 22-24lbs you need to uprate the rods.
My AFN 1.9 110bhp Passat is running 25lbs without issue, I think 28lbs would be fine with a good tune, and plenty of people on here have managed that reliably.
But yes, uprated rods aren't that expensive, so just drop some in and make it futureproof if the engine is already out the car. I have Rosten rods to fit in mine when the engine does next need some work, but for now its around 200chp so not yet needed
AFN Wagon | Fjord Blue | BV43 | 11mm IP | R520 | PD Lift Pump | Ported head | 3bar MAP | SRE Clutch | FHN G'box | Forge FMIC | PD130 intake | EGR delete | Decat | Custom Remap | Porsche 4-pot 312mm Brakes | KW V1 | Carbon Upper Strut Brace, RS4 Lower | H&R 32mm Front ARB | Whiteline Rear ARB | OZ Ultraleg 18" Satin Black | OEM Xenons | Bucket seats | Battery & washer bottle in boot | 100kg removed |
bhodgkiss is offline   Reply With Quote
Old November 29th, 2017, 04:35   #5
bobbiemartin
I'm more interested in what would be the best value if I replace the short block now, with a look to the future of increasing the HP. From what I've read, the later 1.9 blocks were stronger than the ALH blocks and most of the PD cranks had bigger rod journals. It seems an ASZ or ARL short block would be a good starting point as it has the better crank and block. Then add a set of aftermarket rods, bore to 81mm and use BHW pistons. I'm guessing this would be reliable and support 250 HP or more.
Old November 29th, 2017, 05:08   #6
CNGVW
Location: Bob Mann Auto, 111 High St, Pembroke MA 02359
Fuel Economy: Built a 2002 TDI Jetta that got 120 mpg of diesel using a CNG blend.
I have raced my Beetle for over 4 years rosten rods and first over pistons from www.IDPARTS.com . Will last for ever on the last few rebuilds ( blow a head gasket )
I decked the block oringed it and we also used studs I just run the thicker gasket and deck the head to .
Bob Mann
www.DRVOLKS.com
bobtec@comcast.net
VW and Audi Master Technician and TDI Specialist. Bob has over 35 years of experience in the field, and is listed on TDIclub.com as a trusted TDI Mechanic.
Bob is also known for his CNG conversions and is a consultant for Patrick Racing.
CNGVW is offline   Reply With Quote
Old November 29th, 2017, 11:14   #7
[486]
TDI(s): 02 golf ALH
run more rpm and limit torque in software
size turbos so you aren't using half the fuel you inject just to move air
you'll find significantly more durability than most people with terrible tunes and tiny turbos
Old November 29th, 2017, 11:25   #8
FraggyTDI
TDI(s): 04 Jetta
Cheapest best way is to swap your short block with a bhw that's had a balance shaft delete. ALH parts bolt right to the BHW block.
FraggyTDI is offline   Reply With Quote
Old November 29th, 2017, 11:36   #9
bobbiemartin
Thanks. Will the ALH crank sensor work with the block/crank?
Old November 29th, 2017, 12:13   #10
FraggyTDI
TDI(s): 04 Jetta
I believe the pickup wheels on the cranks are different. So you would most likely need to swap that. But the sensor plugs into the same place on the block.
Old November 29th, 2017, 14:13   #11
sam-
He could swap ARL or ASZ crank, rods and pistons in his block also
Old November 29th, 2017, 14:24   #12
FraggyTDI
TDI(s): 04 Jetta
He could but the BHW is far stronger and probably an even an easier swap. Plus if you keep an eye out you can find many 2.0TDI passats with busted trannies for under $1000 Then you can sell it after taking what you want and make back most of your money.
250+ hp Build thread Bdpprocessors TDI Power Enhancements 43 September 4th, 2011 18:27
250+ hp turbo option Bdpprocessors TDI Power Enhancements 24 June 6th, 2011 07:51
Max hp on stock internals??? vti-chris VW MKIV-A4 TDIs (VE and PD) 5 August 9th, 2010 06:09
I need a 250+ wheel HP turbo TooMuchBoost TDI Power Enhancements 22 March 2nd, 2006 17:02
1200 hp Viper vs 250 hp Hayabusa glxke General Automotive 0 May 26th, 2005 01:11
Page generated in 0.18964 seconds with 13 queries
[Output: 108.93 Kb. compressed to 91.90 Kb. by saving 17.03 Kb. (15.64%)]
