Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5)
Audi SUVs (Q7 & Q5) Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US).
Old May 13th, 2017, 14:30   #1
Motodude
Default tire switch
I have a couple 2011 q7 tdi's and was wondering if you can switch 1 wheel off of one and put it on another? or do sensors not allow you to do this.
Motodude is offline   Reply With Quote
Old May 13th, 2017, 20:17   #2
da.hs
If it's the same as the 2010, the sensors are in the ABS, there's nothing in the rim or tire - so you can swap freely if the tires are the same size.
Less accurate than the transmitters in the valves but much more convenient for wheel swapping.
da.hs is offline   Reply With Quote
Old November 4th, 2017, 05:01   #3
Michae,l
Can it really work?
________________
Best Limo Arlington
Michae,l is offline   Reply With Quote
Old November 5th, 2017, 21:15   #4
da.hs
The indirect sensor system? Well, I haven't yet tested it on a puncture or deliberate deflation... It occasionally triggers a warning going over a particularly rough patch of road then cancels after a minute or two..
Changed tires in July from fairly worn, cupped and very noisy tires to new ones of the same size - it flashed up a query either "New tires?" or "Snow tires?" - I forget which - and no warnings since.
2003 Jetta TDI Fan Switch & AC Switch tdimoth VW MKIV-A4 TDIs (VE and PD) 0 December 2nd, 2013 11:06
VW Fog Retro using Toggle Switch vs Light Switch stp1971 VW Passat Family (NMS and B7) TDIs (2012+) 43 September 25th, 2013 00:24
Continuous Thud After Tire Switch BIOWERX TDI 101 5 March 27th, 2011 11:21
2010 JSW tire fails! Freeway incident. Second car involved with damage from tire. Rod Bearing VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 12 September 4th, 2010 10:06
Will A Full Size Tire Fit in a (A3) Spare Tire Well? Ric Woodruff VW MKIV-A4 TDIs (VE and PD) 10 September 4th, 1999 01:41
Page generated in 0.14661 seconds with 13 queries
[Output: 60.65 Kb. compressed to 54.32 Kb. by saving 6.33 Kb. (10.44%)]
