Wntrmoon
Hi Folks, While changing the passenger side front headlamp bulbs on our 2002 Jetta TDI sedan, I was just about through and as I pushed the plug onto the back of the bulb all of a sudden something gave way. It was as if the reflector portion of the headlamp assembly snapped out of place. I looked to see that there was no damage and I could not see any screws or clips that had come loose. It appears the reflector snaps into place. The headlamp works but the reflector is loose. Is there a way to repair this without removing or replacing the entire headlamp assembly? Any thoughts or advice would be appreciated. Thank you. gg
