I was checking the tire pressure on my 05.5 jetta tdi today and while pumping up the front tires, I was looking at the brake pads to check on them and I noticed that the outer pad (maybe inner too, I couldn't see it) on both wheels is wearing uneven. The inner part of the pad (closest to the lug nuts) is dragging pretty good on the rotor while the outer part of the pad (furthest from the lug nuts) has a good 1/4 inch of clearance between the pad and the rotor. I have 38000 miles, does this sound like a problem that would be covered under warranty? The first thing that I can think of is something wrong in the caliber. Anyone else had this problem? What is likely the problem?
P.S. What pressure would you put in 235 45 17 tires? They had 32 all the way around, but I put in 43 in the rear and 41 in the fronts. Is that about right?
Hurst
Hurst
