brady rogers
- Joined
- Jan 22, 2013
- Location
- oklahoma
- TDI
- 03 jetta 5sp TDI, 2010 bmw x5d, 81 1z MTDi Caddy, 97 jetta tdi
Hey guys quick question here, ive got a 2003 jetta alh ive been slowly building as time and finances allow. Right now Im running the stock turbo, rc3, 2.5in straightpipe exhaust from turbo back, frontmount intercooler and upgraded piping (no leaks ), pp764's pd150 manifold etc. Ive also upgraded the drivetrain with performance shocks and struts, drilled and slotted brakes, rear sway bar, bushings, .658 5th and 15spoke gti 17" wheels. So ive got a gtc1549vz that ive built adapter plates, 1z manifold and stuff so it will work on the engine. Im looking to get at least 180hp out of this thing but I want it to be reliable. Im thinking if I have to pull all the stuff off the backside of the head to install the turbo, I might as well pull the head off and have my machinist buddy port it and rebuild the head then put arp studs in it. I will also put a cam in it while im there. My main question I guess is while I have the head off to work on it, is it possible to put upgrade rods in as well, (without pulling the engine) and should I mess with the rings or anything while im in there? my car has 230k on it doesnt use much oil. Thanks
