What happened to your ECU that it needs repair ?Where can I go to get my ECM repaired. I have a 2002 Jetta TDI.
Yes ,
how do you know your ECU is bad???
pm sentSorry for the long answer. Here goes.
Car would start and then die. Would not keep running. Just start then die. Bought Memoscan diagnostic tool to check for codes. Code came up for imobolizer. I trailered car to two dealerships and they couldnt or wouldnt tell me whats wrong. Even tried to tell me intake manifold was pluged. I knew better. Car ran I shut it off next day it would not run. I took it home and bought a manual for the car. I figured computer would not let it get fuel. I located the fuel stop valve for the injecter pump. I checked voltage to the stop valve and nothing. I removed the power wire and jumpered from the battery to the stop valve and car started right up. For grins and giggles I checked the voltage on the power wire for the stop valve and now had 13 volts. I disconnected the jumper and turned car off. I reconnected the power wire to the stop valve and the car started right up. I installed a fused bypass to the stop valve and drove car for year an a half. A couple of time I would have to use the switch to start car but only after it had been turned off. One day wife was driving car to work and it died on her. I used the bypass started the car and drove a few feet and car died again. It will not run long with out the bypass. I figured I had a bad connection so I took every connection apart and checked continuity on the wire and can find nothing wrong with the wireing. All connections are clean and good. All I can figure is an intermitant failure with the ECM.
I would 100% check and see is it ECU or something else.If you sure that ECU is bad ,best and cheaper option is get used ECU and do Immo delete so ECU will be plug and play.Sorry for the long answer. Here goes.
It looks like your alternator not charging.I only used jumper to get car started after that I turned bypass back off. Problem is car won't drive with it off now.Will run without moving but if I drive a few feet it dies. That is what led me to to believe it is a connection problem but cannot find anything there either. You say there could be other things that could cause this. I am open to suggestions!
Thank you for any help you can give.
I actually called about mine yesterday. 2000 NB TDI automatic. I also live in Indiana. ECU repair now in Marissa Il fixes those. $275 shipped. They will test, repair and ship. I believe it was a 1yr unlimitted mile warranty. (618) 303-6957Hope this helps. Chas
It s just waste of the time and money. I have number of the people went this route and on the end they replace ECU.Thank you I will definately call them.
I want to wait to send it in. Hopefully some one on here can give other ideas to check before I do.
Thanks again.
Even new ECU does not cost that much.I really do not know where did you look for it.So you reccomend a used ECM. The cheapest new one I found is a little over $1000.00 plus the immo delete.
Here you go:So you reccomend a used ECM. The cheapest new one I found is a little over $1000.00 plus the immo delete.
