TDIsyncro
The Rods are a custom length as well. I should have mentioned that above. The ASB has a different compression height than the 1.9/2.0 series. Also, we are running a fire ring, so this effects required rod length/block deck height.So these pictons have stock 30mm pin and no bushing, is the rod length equal to a stock TDI one with stock block height? Are those chevy bearings also of sputter design or are they non cracked with the coating?
I do not think the Chevy bearings are sputtered, which made me a bit skeptical, but all levels of tehcnical support assured me they were supperior for longevity and load. There are Chev V8 applications out there running 900-950ft-lbs torque on this bearing, which is in the same ball park for bearing load that we are talking about at the low end, and certainly much more HP/rod and RPM for the upper range PV rating of the bearing. These facts give me more level of comfort in the choice than using the OEM bearing. Time will tell if it was a good choice or not.
