PRY4SNO
Yesterday the wife drove into the city as usual and the glow plug and DPF lights went haywire. She limped it to work and let me know. I had her pull/clear codes and this is what came up:
OBDeleven data log
Date: 2018-06-18 17:02
VIN: 3VWKL7AJ0AM622321
Car: Volkswagen Golf Sportwagen TDI
Year: 2010
Body type: Saloon
Engine: CJAA
Mileage: 243970 KM
01 Engine
System description: R4 2,0L EDC G000SG
Software number: 03L906019CL
Software version: 9971
Hardware number: 03L906022TS
Hardware version: 78
Coding: 0350072
Trouble codes:
P0135 - O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction Lower limit not reached
static
P0141 - O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction Lower limit not reached
static
P0136 - O2 Sensor Circ.,Bank1-Sensor2 Malfunction mechanical malfunction
static
P13D9 - Sensor for internal pressure of cylinder 4 Implausible signal mechanical malfunction
Intermittent
P13D3 - Sensor for internal pressure of cylinder 2 Implausible signal mechanical malfunction
Intermittent
P13D4 - Sensor for internal pressure of cylinder 3 Electrical error
Intermittent
P13CE - Sensor for internal pressure of cylinder 1 Electrical error
Intermittent
P2463 - Diesel Particulate Filter - Soot Accumulation
Intermittent
Had her clear the codes and take it to the dealer for the dieselgate fix.
Because the codes came up again (no surprise, the wiring for the rear O2 sensor was totally chewed thru by mice) they pulled the codes again. Couple things changed.
Dealership diagnostic pulled the following codes:
P2454
P0135
P0141
P13D3
P13CE
P13D4
P13D9
So there's basically the same group of codes and a couple that changed.
Looks like my core issue is the wiring harness to the rear O2 sensor and the glow plugs are intermittently failing due to either mechanical or electrical issues.
The dealer won't fix the car until the issues are fixed and there is no MIL but they want 5hrs to do a full diagnosis at $165/hr. Um no. I found 4 Beru glowplugs in stock in town for $30/each (!!) so when they are delivered I'll be swapping out glowplugs in the dealerships parking lot lol.
Anything I'm missing or something I should look into?
Thanks guys!!
OBDeleven data log
Year: 2010
Body type: Saloon
Engine: CJAA
Mileage: 243970 KM
01 Engine
Coding: 0350072
Trouble codes:
static
static
static
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
P2454
P0135
P0141
P13D3
P13CE
P13D4
P13D9
Thanks guys!!
