04whitetrain
Hey guys, I was wondering if there was anyone relatively close to me 16342 (zip code) that has VCDS/VAGCOM that could help me out. I have on 04 BEW PD that is failing boost. I did vacuum test on lines and everything seems fine, haven't found any cracks or leaking in hosing/piping, but does make whistling noise when driving. Unfortunately, only builds boost to 5psi then goes into limp mode and won't allow you to build boost from thereon until you cycle the key and restart. I tried unplugged the throttle position sensor and driving it, it will allow it to only build up to 9psi but no more and then if you plug it back in does the same thing by going into limp mode. I checked the wastegate actuator and rod actuator, all good. Check engine light code is P0299 (underboost). Any help or suggestions would be greatly appreciated.
