Hello All,
I have been pondering this for a while and think i am going to go ahead with it, I am looking for advice from all the Turbo Sizing Guru's on what turbo I should pair up with my current GTB2260Vk, The reason i am asking isnt because i want to run a stupid amount of power on the street... I already have traction problems in 2nd as it is.. What i am concerned about is my EGT's. When i lived in Colorado my EGT's RARELY hit off the EGT Hard Cut Mark Malone placed on the car of 950C, but since moving to Florida the spoolup is MUCH sooner and im hitting HIGH EGT's much sooner in the RPM's range.. When the weather is cool outside i dont have a problem with the car hitting peak EGT's and cutting fuel.. but lately with the high 80's days we are having again since moving here.. the car will pull strong and hard a few times in traffic but after a few miles the EGT's are staying pretty high and i hit the 1050C fuel cut limit that is currently set and the car becomes sluggish for a while tell they cool down and then its a never ending cycle. Today i did logs and im seeing timing being pulled literally half the drive from point A to B because of EGT's getting up there.. When the sun sets and the temperatures are in the 60-70's the car pulls like a freight train, but when the sun is out and its 88+ temps outside.. she is struggling..
I am currently only set to peak at 32PSI, so i need more air.. more effeciently..
What turbo would everyone think would match up with the 2260 to just help it out. I know its rated for around 35 in flow.. so maybe a 40-45 size turbo in flow to split the load??
GT2871r 44lbs
GT3071r 49lbs
Here is a graph of a recent data log of spoolup.. if that helps with anything.
GT2871r 44lbs
GT3071r 49lbs
