Old October 28th, 2012, 09:13   #1
vrus13
Default Low power,limp mode
Hi! My car is:Passat 1.9 PDTDI, 2003,AVB(101HP)(200.000km). This is my first diesel car,i bought two months ago.The car hasn't power under 1800-2000rpm.I push the throttle full down and my car accelerate slowly.At 1800-2000rpm kick out and accelerate very fast,but over 3000rpm the car goes limp mode.2 months ago i had the following error msg: 17965 charge pressure control positive deviation p1557 - 35-10 intermittent. My turbo was cleaned. But now,i have this error msg again. I logged the block 11 with vag-com. The duty cycle is 94,4(2500rpm).What is the problem?MAP?MAF?Actuator?Turbo? Pls help me. (Sorry for my bad english)
vrus13 is offline   Reply With Quote
Old October 29th, 2012, 08:33   #2
vrus13
Nobody?
Old October 30th, 2012, 09:08   #3
vrus13
I was logging group 3 and 11. I don't know why,but my map duty cycle is high.At 2500 rpm 90%! Have i faulty n75 valve or somthing is bad with my actuator? Must i adjust the actuator rod or replace the n75?
http://postimage.org/image/m7ynorrdj
http://postimage.org/image/maijblv13
Old October 30th, 2012, 09:21   #4
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Many of the boost lost problems with these diesels are due to a leak in the charge hoses (large diameter). In the U.S. versions, the hoses have o-rings as seals. Inspect all the hoses to and from the turbo and intercooler for a start.
Good luck!
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old October 30th, 2012, 09:23   #5
aja8888
aja8888's Avatar
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
19586/P3130/012592 - EGR System: Regulation Range Exceeded
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Exhaust Gas Recirculation (EGR) Valve (N18) faulty
Exhaust Gas Recirculation (EGR) faulty
Possible Solutions
Check/Replace Exhaust Gas Recirculation (EGR) Valve (N18)
Check Exhaust Gas Recirculation (EGR) faulty
Old October 30th, 2012, 09:24   #6
aja8888
aja8888's Avatar
Maybe read this too:
http://forums.tdiclub.com/showthread.php?t=179589
Old October 30th, 2012, 09:26   #7
vrus13
P17965, it's an overboost error. I think this is not leaking problem.
Low Power no Limp Mode autenje TDI 101 2 August 1st, 2012 20:02
Help! Low power limp mode code 1556 all the sudden 2000BEETLETDI TDI 101 6 July 24th, 2012 16:19
Low Power, no limp mode TDIBrandon VW MKIV-A4 TDIs (VE and PD) 6 February 27th, 2012 04:44
Low power no code or limp mode? jjsbiggs VW MKIV-A4 TDIs (VE and PD) 10 June 10th, 2010 15:59
Another A3 low power - limp mode thread steve b VW MKIII-A3/B4 TDIs 12 January 6th, 2010 10:00
Page generated in 0.15958 seconds with 11 queries
[Output: 80.36 Kb. compressed to 69.74 Kb. by saving 10.62 Kb. (13.21%)]
