Old October 1st, 2011, 20:08   #1
db52282
Fuel Economy: 38 - 41 MPG
Default Alternator Workshop - Bad Alternator or VR?
Wife's 2005 Passat TDI (BHW) got the battery light and the Alternator Workshop notification (with the beeping).
Alternator pulley was replaced (new style) around 30K miles ago.
I have not determined whether I have the Valeo or Bosch alternator yet
but am leaning toward replacing the voltage regulator rather than the
entire alternator. The rebuilt units are VERY expensive.
Has anyone had the same problem and a voltage regulator replacement fixed the problem?
I read in the TDI 101 section that you should only replace the alternator if you have a bad bearing.
Any ideas or help is appreciated.
2005 Passat TDI (Unchained 05/03/2011 @ 87273 Miles)
2007 Chevrolet 2500HD Duramax LBZ Diesel
db52282 is offline   Reply With Quote
Old October 1st, 2011, 21:14   #2
afarfalla
afarfalla's Avatar
get a voltmeter, set it to voltage, put the red lead to the bat positive, blk to the neg, read bat voltage, start the car, if the bat is weak the voltage should go up higher than the first reading, in any case the voltage should be around 13 to 14 volts, now turn on the lights radio anything that draws power, if the regulator is good the voltage should hold
afarfalla is offline   Reply With Quote
Old October 2nd, 2011, 04:51   #3
thundershorts
battery condition/age? Most auto stores will test your battery and charging system for no charge(pun intended)
"You can't argue with a fool..."
thundershorts is online now   Reply With Quote
Old October 2nd, 2011, 05:18   #4
db52282
I had the battery and alternator checked at the parts store. Battery age unknown.
Results: Battery tested good - 12.4v
Alternator: Failed - Producing 12.1v (Load or No-Load Condition)
Any additional advice?
Old October 2nd, 2011, 06:44   #5
Skivvies
I had a similar problem, and when testing at the battery as suggested with car running I got less than 13vdc. The voltage would intermittently spike and the engine rpm would fluctuate in accordance with this spike (indicating the alternator was coming into and out of the loop), but for most of the time the voltage was below 13vdc. Pulley had already been replaced with new style but I checked the clutch mechanism anyway.
I replaced the voltage regulator and alternator output returned to normal. I would replace the regulator with one from the dealer (P/N 038903803EX). The cost was the same as online and it got to me in a day or two with no shipping charge. You can do it without removing the alternator.
I will add that at this time the battery looked like the original and a few months later it needed to be replaced. Whether it contributed to the failure of voltage regulator I don't know.
Skivvies is offline   Reply With Quote
Old October 2nd, 2011, 12:09   #6
db52282
Do you have a Valeo or Bosch alternator?
Is this part number the same for either the Valeo or Bosch?
Thanks for the information. I was heavily leaning toward replacing
the VR anyway.
Old October 2nd, 2011, 16:46   #7
thundershorts
did they give you a printout of the system test? if the battery is original Varta I would consider replacing it with the vr or alternator. it might still test good in warm weather but may give troble when it gets cold
Old October 2nd, 2011, 17:28   #8
Skivvies
the VR anyway.
alternator is a Bosch 120A P/N 028903031. This is printed on the backside of the alternator. You can give whatever alternator P/N you have to the dealer to find regulator P/N. The following site has all the info you need including the Valeo and Bosch regulator P/Ns:
http://www.myturbodiesel.com/1000q/b...at-removal.htm
Old October 23rd, 2012, 00:29   #9
Za786
TDI(s): Passat tdi
Default 04 Passat Tdi alternator workshop
Hi guys,
My alternator light came on the problem was the pulley was gone as when I turned the steering it would squeak.. After I got the pulley changed it was fine.
Now after a month i went to work every morning 30 mile journey each way and no problems but as soon as I returned home in the evening and switched the car off and on immediately the light came on.
Now from yday the light came on immediately and no problems on battery draining yet. The alternator is showing more than 13v
Does anyone know if it's the regulator? Where does that sit and how much is it?
Any help will be appreciated
Za786 is offline   Reply With Quote
Old October 24th, 2012, 07:46   #10
abctdi
abctdi's Avatar
Maybe new brushes will help?
When my pulley failed, I measured mine since they were easy to get to and they were still long enough.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
alternator workshop krober VW B5 Passat TDIs 2 February 18th, 2010 14:50
Alternator Pulley bad, now Alternator? danielalves VW MKIV-A4 TDIs (VE and PD) 6 July 28th, 2009 04:32
Alternator Workshop b5r VW B5 Passat TDIs 2 March 22nd, 2009 10:36
alternator workshop? diesel#2 VW B5 Passat TDIs 6 June 12th, 2008 19:26
Alternator Workshop! What does it mean? Occams_Razor VW MKIV-A4 TDIs (VE and PD) 5 December 20th, 2003 13:40
Page generated in 0.15870 seconds with 11 queries
[Output: 96.26 Kb. compressed to 81.92 Kb. by saving 14.34 Kb. (14.90%)]
