Hatchet Ratchet
OK, here it is! I found the solution for not knowing what color goes to what and not wasting time chasing down signal wires.
I choose a circut protected unpowered converter from etrailer.com that will work with LED lights. It is a Drawtite and it was $20 + shipping.
You'll need to use a signal converter due to the seperate bulb functions found on imports and new vehicles that don't have T-One connectors available.
It may be your prefernece to choose a different converter, such as a powered one, but the main thrust of this post is finding the signal wires you want fast, easy, and with NO Splicing and NO Scotch Locs.
on the back of your tail light bulb cluster are spades that can easily be tested by a cheap 12v tester(probe w/ light). using the tester you can connect to the stud from your tail light as shown below where the white ground wire(below photo) attaches from the signal converter and test each of the spades for the signal you wish to sample from your converter.
I didn't label each of these, just use your tester, and connect a female insulated spade connector to the end of the signal wire from your convernter and plug it into the correct male spade in the back of the tail light bulb cluster.
you need to use the insulated kind as you can see that there are two connectors that touch each other and would touch another spade to the left of the center(blue one). i cheated and only used one insulated spade for the blue one and the rest are uninsulated connectors as they don't touch any other male spades.
I mounted the converter to the inside of the truck where the cd changer would be located. On the back of the converter that I choose was a self adhesive pad for easy installation.
Just replace all covers and stow your wiring in your compartment above your CD changer.
HAPPY TOWING!
HAPPY TOWING!
