Old June 5th, 2007, 15:12   #16
JB05
Fuel Economy: 43/41/40
Thanx for the responses Grizzly and rdkern.
JB05 is offline   Reply With Quote
Old June 6th, 2007, 07:45   #17
tnteggroll
Where can one find vacuum line to replace the lines in my car? It seems simple enough to do myself, hopefully fix my stupid limp mode problem, and also doesn't seem like it would take too long. I just don't know where to find the vacuum line, what it's called, size, etc. Any help?
tnteggroll is offline   Reply With Quote
Old June 6th, 2007, 19:42   #18
roachxp
I tried VAG and this is what I got, but it could be many things.
I'll take it to the dealer to fix.
Address 01: Engine Labels: 038-906-012-CP.LBL
Part No: 038 906 012 CP
Component: 1,9l R4 EDC G000SG 2839
Coding: 00002
Shop #: WSC 00000
1 Fault Found:
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 35-10 - - - Intermittent
Readiness: 1 1 0 0 0
roachxp is offline   Reply With Quote
Old June 6th, 2007, 19:55   #19
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
Coding: 00002
Shop #: WSC 00000
1 Fault Found:
Take it to the dealer at your own risk... this is why I posted the write up so that you can diagnose yourself. You have a overboost condition with limp mode. It can be resolved if you follow our advice.
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old June 6th, 2007, 20:33   #20
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Originally Posted by the ING man
Save Your Money
You're less than an hour away from one of the outstanding TDI techs around... Chris Hill runs Kraftwerke Autotechnic in Braintree...
(781) 849-5888 UserID here is "MrCHill"
He'll fix it the right way for a lot less than the dealer (who probably won't...)
Yuri.
ymz is offline   Reply With Quote
Old June 6th, 2007, 21:16   #21
roachxp
Thanks I'll have to give him a call.
Old June 7th, 2007, 09:35   #22
skrewdriver
Vacuum Hose:
If you search this forum for 'mcmaster', you will find a post that says exactly what you need hose, and where to order it (mcmaster.com). I ordered a bunch from the mcmaster site, and it arrived very fast and worked great.
skrewdriver is offline   Reply With Quote
Old June 7th, 2007, 13:22   #23
BuffaloDiesel
Originally Posted by skrewdriver
Vacuum Hose:
You don't even need to do a search. Look at the first post in this thread for a link to a list of hoses you need as well as the links to the McMaster Carr catalog to buy it.
BuffaloDiesel is offline   Reply With Quote
Old June 9th, 2007, 09:26   #24
tnteggroll
Okay, need some opinions/thoughts.
Been having limp mode problems for a while, had the turbo rebuilt, still does it but not quite as often. Just went from Vancouver to Edmonton, and found it was still cutting out at high speeds/uphill etc. However, the car did not go into limp mode once when i left it in cruise control. Even at 130km/hr uphill, it never went off so long as it was in cruise.
Now, after spending the 13hrs thinking of why, im figuring it would be the N75, would it not? If it was a sticky turbo vane or leak in my vacuum lines, it would go into limp mode regardless of whether i was controlling the speed, or the computer (cruise), right? It would make sense that it wouldn't cut out in cruise, if the car itself was controlling the speed/boost pressure. At least that's what I am thinking. Any thoughts? I'm going to call around in the next day or so to see if I can find a new N75 solenoid in Edmonton, and change it out before I go home. Just kind of hoping someone can confirm what I'm thinking is, or should be, correct. Thanks for any info.
Tom
Old June 9th, 2007, 20:33   #25
Canadian_Grizzly
Tom, prior to buying a new N75, swap the EGR solenoid with the N75. EGR is just to the left of the N75 and see if that helps. I've never heard of a difference between cruise and your foot prior to this thread....interesting.
Byron
Driver Found!
Old June 9th, 2007, 21:25   #26
MCR
In the "Other Maintenance Issues" section, I'd recommend adding something about a clean air filter. I just bought a 2003 Jetta with 74000 miles, and the air filter and snow screen were *really really* dirty. I haven't had a limp mode since I cleaned the snow screen and put in a new air filter. The air intake is going to be cleaned as soon as I get the 80K maintenance finished.
It seems like the "Other Maintenance" section is secondary the way it's placed. Is that the intent? I'd almost think these should be the first things to check.
MCR is offline   Reply With Quote
Old June 11th, 2007, 09:08   #27
tnteggroll
One other thing, after stopping and shutting off the car, I tapped the N75, just for kicks. And it made a large zzzz'ing sound, like a fan winding down, lasted about 3-4 seconds. Can't imagine thats a good sign of health either.
Old June 11th, 2007, 09:12   #28
tnteggroll
To test if the N75 is off or not, after switching with the EGR, can I drive the car to test it? What is the actual purpose of the EGR solenoid?
Old June 11th, 2007, 14:12   #29
tnteggroll
Okay, so while removing the N75 solenoid, i snapped off one of the vacuum pipes. Guess I'll go ahead and replace the solenoid afterall! ....damnit. Haha.
Oh well, kind of leaning towards that being my problem anyway, and a new one won't hurt the car. Only $89 here in Alberta, not bad.
Old June 11th, 2007, 14:22   #30
doc_m
doc_m's Avatar
TDI(s): None
Ah lol tom hope it all works out
Do work on cars like intake cleanings, nozzle swaps, brakes etc.... Hex usb + can now
2009 Jetta TDI Comfortline with ESP and beige leather interior. Evolution Imports Osiris Skidplate.
So far just over 10,200 kms on it
doc_m is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Audi A4 Low power and limp mode and other problems arijus TDI 101 5 August 9th, 2018 15:34
Low power,limp mode vrus13 VW B5 Passat TDIs 6 October 30th, 2012 09:26
Low Power no Limp Mode autenje TDI 101 2 August 1st, 2012 20:02
Low Power, no limp mode TDIBrandon VW MKIV-A4 TDIs (VE and PD) 6 February 27th, 2012 04:44
First time diagnosing low power / 1x/limp kiva822 TDI 101 35 July 30th, 2011 05:10
Page generated in 0.17359 seconds with 11 queries
[Output: 125.02 Kb. compressed to 104.56 Kb. by saving 20.46 Kb. (16.37%)]
